F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Articles & How-To's
Thread Tools Display Modes
  #31
Old 08-28-2008, 11:59 PM
Vehicle: 2001 Ford F150 4.6
The kit is made by Richmond Gear. My cousin recommened them after he had great success with them in his Bronco. Anyone heard of or used these gears before?
  #32
Old 08-29-2008, 10:25 AM
Vehicle: 2003 Ford F150
I've heard of them but don't know anything about them.
  #33
Old 09-09-2008, 11:39 PM
Got my gears in over the weekend. It wasnt too bad of a job took about 4hrs to complete with two people. (My cousin doing most of the work, me being the "go for" haha). Man what a diffrence those 4.10s make its like i have a whole new truck. I have experenced power that I never thought the little 4.6 was capable of putting out. I would def recomend 4.10s to anyone who is looking to get more out of their truck but dont have thousands to spend in afteramarket mods. Havent really taken notice to gas mileage but what a difference it makes in the city. Thanks for all the advice guys I would never even thought of a gear swap if it wasnt for this forum.
Thanks Again,
Duane
  #34
Old 09-10-2008, 10:25 AM
Congrats man! I thought the same thing after I did my gears.
  #35
Old 11-05-2008, 11:52 PM
Vehicle: 2007 Ford F150
I also have a 3.55 from the factory. The Richmond gears are suppose to be favored by guys building race cars. After a little shopping around, I settled on Ford Racing Performance Parts 4.10. The main consideration was the price. My local dealership is a Ford Racing vendor. The install was at my local 4WheelParts.com. When the 35" tires went on with the lift kit, I noticed a drop in mileage and performance. With the 4.10 gears, my truck seems to drive better than it did when it was new.
  #36
Old 01-22-2009, 05:08 PM
Quote:
Originally Posted by 05_sprcrw View Post
It is a good idea to change the gear oil after the first 500 miles in order to remove any metal particles or phosphorus coating that has come from the new gear set. This is cheap insurance and a good time to discover any problems before they grow to disastrous proportions."
Man, you should have seen the stuff that was floating around in there. Luckily, I have a Mag-Hytec differential cover with a magnetic dipstick & drain plug. Most of the metal particles stuck to the magnets. The Royal Purple was clean & purple going in, but thick & black coming out. Everybody should change out their fluid after the initial break-in period, and continue to monitor it closely the first few thousand miles.
  #37
Old 02-13-2009, 01:08 AM
Vehicle: 2004 Ford F150
just markin it, thanks for the info
-=2004 F150 NBS 5.4L 2WD SCab=-
305/55 Nitto TG's on Gear Alloy Double Pump 20"s
  #38
Old 10-29-2009, 01:21 AM
Vehicle: 2005 Ford F150
I just wanted to add a few thins i think are important.
1. the shim under the pinion should be used as a referance point. it will get you ballpark into your pinion depth but not always will it be correct. unless your stock gears have a depth writen on them and the new gears depth is the same. you may have to install th pinion without the crush sleeve and get a mesh patteren to verify the pinion depth is corect ot use a or make a tool to check the pinion depth. then install the crush sleeve or spacer kit. . as a cheater tool you can add a pinion shim to the crush sleeve and reuse it since they are a pain to crush.
2. backlash and runout should be check both can be done with a cheap dial indicator. you cant assume the shims that were stock will center the ring and pinion the same as the stock one did. and provide the needed back lash.
deffinatly utilize bill vistas gear install for help.
  #39
Old 11-06-2009, 02:04 AM
Vehicle: 2006 Ford F150
Sometimes i hate this site! I need NEW GEARS ASAP!!! Thanks for a fantastic write up and input! I'll be back asking questions for sure!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
