How to Fix a Defective Window Switch
Old 07-23-2010, 10:59 PM
blackjack8900's Avatar
Just did mine yesterday
Works like new now!
thanks for the detailed pics!
  #47
Old 07-24-2010, 03:33 AM
mblouir's Avatar
You are both quite welcome!
  #48
Old 07-24-2010, 05:05 PM
whodeymarvin's Avatar
Mblouir, Thanks so much for the tutorial. you are spot on. Just worked for me also. Again thanks to you and the other posts for taking the time to post step by step instructions I've used for fixes on my truck in the past
  #49
Old 07-25-2010, 12:12 AM
mblouir's Avatar
Glad to help....and welcome to the site. Post more often!
  #50
Old 07-27-2010, 08:34 PM
Shanks12's Avatar
Going to be doing it this weekend... Will have my computer next to me so I can follow this... But I think I can probably manage without it.. seems pretty straight forward
Glad to see you put up new pictures!
  #51
Old 07-28-2010, 02:11 AM
mblouir's Avatar
The steps between pics 3-5 are the hardest. Prying the little box apart was the toughest part for me, even when I went back to take the 2nd set of pictures. If you have any problems shoot me a PM and I should be able to hit you back pretty quick (I check email regularly throughout the day).
  #52
Old 07-28-2010, 10:17 AM
Shanks12's Avatar
Sounds good man.. appreciate that!
Also, when you said you used Q-Tips to clean the surface, is that all you used... or did you use sandpaper/wire brush or anything to try and scuff the surface, or are you basically just looking to get the gunk off?
  #53
Old 07-28-2010, 03:37 PM
nightingale's Avatar
Just did this on my 06 and it worked great. I'm apparently not as technically gifted as some of you because it took me about 30 mins.
Thanks for the writeup.
  #54
Old 07-28-2010, 04:08 PM
Shanks12's Avatar
Yeah, I've heard getting the clips off is the hardest part... But hey, As long as you got done and saved yourself some money..
  #55
Old 07-28-2010, 04:50 PM
Yup, the clips took at least 15 minutes, which shows how easy it is to do everything else.
  #56
Old 08-01-2010, 12:07 PM
Shanks12's Avatar
Good work Matt.. Worked like a charm! Window works much better now.. I'll put a pic up later today..
  #57
Old 08-01-2010, 08:32 PM
mblouir's Avatar
  #58
Old 08-01-2010, 09:16 PM
Shanks12's Avatar
Here's what mine looked like... As you can see, they were pretty bad!
  #59
Old 08-01-2010, 09:28 PM
mblouir's Avatar
Love it!
  #60
Old 08-07-2010, 03:32 PM
pat28's Avatar
Mine is DONE ! Thanks mblouir for the how-to!
Quick Reply: How to Fix a Defective Window Switch
