Auxiliary backup lights installed (How to/pics)
Old 11-30-2009, 03:27 PM
thorherc67's Avatar
awesome job i am planning on doing this very soon!
  #32
Old 12-01-2009, 08:28 PM
jhrsmail's Avatar
ditto...clean job, added to my list
  #33
Old 12-11-2009, 06:41 PM
Grunthunter's Avatar
Blackjack,
I spotted these same lights yesterday at one of our local parts store only they were packages under the name Blazer White Lights ( UW3534 ( for $39.95. They were packaged identical to the ones you show. Interestingly, when I was looking at them it looked like they would throw a vertical light beam rather than a flat horizontal beam you would want for fog lamps. I would like to set mine up so they would work with the backup lamps but also be able to turn them on independantly. Reason for that is on the ranch where our hunting lease is we have a lot of gates and gaps we have to open and close and when I'm out there by myself I'd like to have some rear lights on when I have to go back and close a gate.
Question is, what kind of a directed beam do they project?
  #34
Old 12-16-2009, 10:30 PM
Blackjack,
Another question, how did you fasten them to your bumper? Did you have to drill new holes in the bumper or are they clamped on from the back side. I don't see any holes in my '09 Platinum bumper in that area.
  #35
Old 12-18-2009, 09:22 AM
Originally Posted by gixxerjasen
I thought the same thing too till I saw his pictures. Then I thought, "Hey, that'd be really useful for hooking up the trailer in the dark." It shouldn't be too big of a challenge to make them come on with the reverse lights and also with the switch. Just wiring the relay properly. I like this idea.
That's the wiring scenario I'd like to do because I am going to put backup lights on my trailer but I also want to have additional lights at the back of the truck. I'd like to have them tied into my backup lights but also be able to switch them on without the truck being in reverse because most of the time I am by myself. Anybody have an idea on how to do that? I actually have two vehicles I need to do this to.
Also, what do you think those dark lights would look like if they were mounted on the plastic next to the license plate lamps instead of under the bumper where they could get damaged somehow?
  #36
Old 12-22-2009, 08:59 PM
hllon4whls's Avatar
As far as the wiring goes, its very simple. The reverse wire runs up the passenger side and goes above the fuse box. Its a pink wire with a black stripe, the same wire thats at the trailer connector. You can use that signal to activate the relay. Put a diode inline with the relay and you can tie an external switch into the relay side of the diode. This will isolate your trucks wiring from all aux light wiring and prevent a reverse emf spike generated by the realy from reaching the truck.
If you dont know about diodes, get a rectification diode from radio shack. To make current flow through the diode, orient the stripe towards the grounded side of the circuit.
Edit: added pics
If you look closely, you can see the wire tap that I put on the reverse wire. This is from the passenger side kick panel.
Here is a crude diagram of how to wire things up. Use fuses as close to any 12v sources as you can. You can get the diodes at radioshack still.
I used a 30amp lighting relay, you need one sized appropriately to handle the current draw of your lights. The switch circuit and diode are only going to support the current required by the relay coil to activate. Use a 1 amp fuse, 5 amp max. On the aux light circuit, use a fuse sized for the lights.
When the reverse lights are on, the aux lights come on. When you flip the switch, the aux lights come on. They stay on until you turn them off. The reverse lights nor the trailer reverse lights will come on with the manual switch.
I love this setup. I have reverse lights on may trailer too. I park my trailer in my yard. The reverse lights make it easy to back into the yard without hitting trees. These lights under the bumper make life very easy for hooking a trailer and for backing up in dark areas.
  #37
Old 12-22-2009, 09:50 PM
Does the pink wire with the black stripe then go to the round trailer connector also? This is GREAT and I greatly appreciate the feed back. This is something I am definately going to do. First I'm going to need to rewire my trailer with a 5 wire system so I can add backup light to the trailer also. Yeah, at night I have to back my trailer a good 75 ft up my driveway to park it.
  #38
Old 12-22-2009, 10:45 PM
DJ2007's Avatar
Edit: added pics
I did the same thing except I used a SPDT switch. The lights come on when in reverse or I can switch them on whenever. https://www.f150online.com/forums/me...ap-lights.html I'll get more and better pics of the setup when it quits raining here. I wish I had a better wiring diagram but that's the best I could do. I used the same reverse wire found in the passenger side kick panel. Once I figured out the wiring, the rest was easy.
  #39
Old 12-22-2009, 11:36 PM
Glen R's Avatar
Looks great. I plan on adding back ups the same time I do my front lights. I had planned on flood lights, but I like the low profile look of the compact fogs. That is probably what I will end up going with. I think I am going to go with a remote switch for all of my lights. That way I do not need to run wires into the cab, and I can wire the remote to the ignition. Figure I can use the remote switch to trigger the relays for each set of lights.
http://www.autobarn.net/plsw29.html
  #40
Old 12-22-2009, 11:54 PM
Originally Posted by Glen R
Looks great. I plan on adding back ups the smae time I do my front lights. I had planned on flood lights, but I like teh low profile look of the compact fogs. That is probably what I will end up going with. I think I am going to go with a remote switch for all of my lights. That way I do not need to run wiresinto the cab, and I can wire the remote to the ignition. Figure I can use teh remote switch to trigger the relays for each set of lights.
Glen,
Nice post and interesting switching concept. Thanks also for the new web site. I hadn't run across that before.
  #41
Old 01-03-2010, 09:34 PM
snrose's Avatar
any chance of getting a picture of the beam pattern? i'm about to install these on my car
  #42
Old 01-08-2010, 09:30 PM
OhOne150's Avatar
id like to see a pic of the beam pattern as well.
  #43
Old 01-12-2010, 11:19 AM
Ace_boy2099's Avatar
I second..... or third, or whatever number we are at by now.... XP
  #44
Old 01-15-2010, 12:30 AM
snrose's Avatar
i found someone who has these lights and was willing to take a picture for me..i dont think he has them aligned all that well but it gives a good idea
  #45
Old 01-16-2010, 06:14 PM
blackjack8900's Avatar
Update
UPDATE:
Here is an update to anyone that is still planning to do this mod.
I have since changed out the lights for another set. The new ones are made by the same manufacturer as the first set. Reason I changed them out was I have had them through two Minnesota winters and they were starting to rust inside the housing and also one bulb blew out so I thought now is the time to change them.
I went and picked up a set of actual "backup lights" or so that is what the box said, got them from Fleet Farm. Just looking at these I could tell they would give off a wider beam. They give you brackets to mount them to the hitch but with the brackets it made them look too bulky. Instead I just zipped tied them right to the hitch without the bracket, as they fit perfect on each side. Also they came with 55w bulbs and I replaced them with 100w bulbs.
I also moved the switch off the brake controller to right next to the cigarette lighter
Here is a picture of them in the day…
Here they are at night. All I got to say is that I thought the first set was bright but these are at least 3x brighter and also have a much wider and more general beam pattern.
The beam on the left side is getting cut off by the snow bank...otherwise it looks just like the right side...the snow bank behind me is also blocking it too ... But you can see they do light up the neighbors house behind me!!
Quick Reply: Auxiliary backup lights installed (How to/pics)
