05-12-2010, 03:03 PM
Garage is empty, add now
Vehicle: 2006 Lincoln Mark LT
Does anyone have these Headlights?
05-12-2010, 03:42 PM
If those are the ones that Smokey has, those aren't true projectors. It still has a reflector that reflects most of the light. Only a small part of the light makes it through the lens.
Not sure if an ouput pic was ever posted.
2003 Expedition XLT 4.6 V8
AFE CAI
Custom Sniper Tune by Matt
Swapped Maggy 18" Muffler
Summit underdrive pulleys
05-12-2010, 08:34 PM
They are a pretty good looking light, however, that is not a projector in there. It's nothing more than a plastic lens that reflects light onto the chrome reflector. Light output is worse than the stockers are. The pair I had the CCFL were not evenly lit and couldn't get them replaced. What I have done with the ones I have is sent them out and having them retrofitted with true HId projectors and new CCFL rings installed. Costing me a fortune, however I do like the way the housings fit the truck, so for me, it works.
05-13-2010, 12:31 PM
How do the Halo's get power?
05-13-2010, 12:37 PM
2006 Ford F-150
Vehicle: 2006 FORD 150
I have a pair thats the same in black. They fit decent but arent true projectors. They do seem to project a small portion of light further then the main lighted area, but not much.
They halos have wires that you have to tap into somewhere. I tapped them into the running lights so i could run them without the hids on. You can check my album for a few pics
Low -N- Slow Always under construction
05-13-2010, 01:19 PM
Yea, I think most people tap them into the running lights.
AFE CAI
05-13-2010, 10:13 PM
Vehicle: 2006 Ford F150 4x4
My other truck is a hot air balloon!
05-19-2010, 01:05 PM
Ok i got the lights in on Monday installed right away and i love them. It rained last night and now I have condensation in the corners of both head lights. Anyone else have this problem? everything seems snug and tight. ANy quick fix?
05-19-2010, 01:20 PM
Dry them out and put a bead of silicone around them?
AFE CAI
05-19-2010, 03:54 PM
Quote:
a bead of silicone where?
05-19-2010, 04:05 PM
2008 Ford F-150
Vehicle: 2008 FORD F150
your goin to wanna inspect your headlamps and run silicone wherever the lens of the lamp meets up with the actual housing which is black....i.e black and clear lens meet together....
05-19-2010, 04:25 PM
Oh ok, so you dont mean where the bulbs go in. Gotcha
05-19-2010, 07:11 PM
2008 Ford F-150
Vehicle: 2008 Ford F150
i have them. they look good and i like the output while running HIDs but that being said, I would NOT buy these again.
my complaints are that the halo doesnt work and they leak (they even have a frickin drain that will drain after the light housing is half full of water... durrrrrr)
also, the lights came in the mail and the housing was BROKEN. its nothing you can see from outside the truck but it speaks for the quality of this light.
maybe some people have had better luck and i just got a bad set, but i dont recommend these lights at all.
05-20-2010, 05:37 PM
2008 Ford F-150
Quote:
not at all, when you do switch the bulbs from stock over to the new housing make sure all the little rubber gaskets are still there, thats what keeps water and condensation from goin inside, also double checking porper installtion of the bulbs cuz sometimes it will feel like they are in but not installed properly
good luck
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
