Quote:
Originally Posted by enggass
Could either of you give me a brief explanation as to how?
EDIT: I guess my real question is how do you get to the Nuts?
The bolts I see no problem, but how do you access the nuts inside the frame?
there are no nuts inside the frame,. the 2 bolts screw into a bracket inside the frame..If you look at your tow hooks you have one bolt going through a solid hole and another bolt going through a hole with a slot. What you do it just loosen the bolt with the slot a few turns and thats it, remove the bolt with the solid hole.. then slide the tow hook along the slot and off..now screw the other bolt back in. If you unscrew and remove both bolts youll have a bracket swimming around in your frame.. I change my chrome ones out every winter.. Hope this helps.
