Ryan
Thanks to SFX.net 1999 F-150 XLT SCAB 4x4 Mods:BBK Shorty Headers, 33" Yokohama Geolandar MT+, Airaid CAI, Cherry Bomb Glasspack, AVS Bugflector II, Tailgate LED light bar, Sony XPLOD Bluetooth HU, Pioneer Speakers, MTX Thunder Subwoofers, Sony 1100W Amp, ETC. Soon To Come: RCX 5" Suspension Lift, And Lots More. Check Out My Progress Thread: Progress Thread 99' F150 Ram This FORD Dodge Boy!
03 Screw, 4x4, 5.4, 6+3 Lift, Xcal3, 38x15.50x20 Toyo's, 20x9.5 Procomp 7005's, Yukon 4:88's, Super 44's Dual, OBX headers, 3" AF1, magnaflow cats, Firestone Air Helper Springs, Kenne Bell 2.2 S/C'er waiting in garage to be installed, official #2 Patman Grill <Click Here For Photo Galleries> Thanks for the SIG krusedisc!
01 Black XLT 4x2 Screw Gen I, 5.4, Moonroof, 3.55LS, Cloth Captains, Slider, Extender, ClassIII towing, Stull Billet Grill, Line-X, New back up lights so I can actually see something! Lightning Third Brake light and tails, Weathertech window visors. Billet AC Knobs, Bilstein shocks, Mag-Hytec Differential Cover, Amsoil, Superchip Tuner,
Rocking to Adire Koda 6.1 speakers, Polk dx10 sub in Subbox.net box and Kicker kx700.5 amp. Kenwood DPX-701 headunit and Sirius tuner.
First of all it is under your truck and it will never look clean unless you crawl under and polish it on a regular basis.
Secondly, I have read that the chrome plated ones don't dissipate heat well. It would be a step down from the factory cover that comes on the truck for heat dissipation. If you haul anything or tow anything you don't want that.
When my diff cover was leaking I figured I would upgrade as I tow a travel trailer and haul my quad. IMO the Mag-hytech covers were the nicest ones around and the drain and fill holes with the dipstick set them apart from the rest. The price sets them apart too. They are the most expensive ones I saw at the time.
If you are going to change it out I would look for Aluminum with some sort of cooling fins on it. There are a few to choose from. If you just want a painted one paint the factory one and save yourself some cash.
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, True Duel Straight Pipes With X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
I've looked into differential covers before just for looks, and I really like the look of the Mag-Hytecs. If I was to get one what all would be invovled? Would it be worth getting one if I flush the rear axle? I'm at 81,000 miles and thought it would be good to flush it by 80k - 100k and I wanna try to replace my OEM cover with the Mag.
More importantly, would it be worth putting on my truck? I mean its only a 3.73 LSD, leveled, and on 33s, theres no major requirments for them is there? like largwer gears? I do not wish to upgrade gears because I do not plan in lifting or running any bigger tire.
If your going to take off your cover I'd consider getting a new cover.
However, I'm not sure but I don't think you need to worry about your gear oil. I think that stuff pretty much lasts the life of the vehicle.
I wouldn't worry about it till around 130K or so.
Not sure though, maybe someone else will chime in.
If your taking the cover off replace the gear oil. My truck has around 60,000 miles and I replaced mine. I think most guys here are changing theirs out in the 60,000 to 100,000 mile range.
The advantage of the Mag is that it will hold an extra quart of oil and combined with the cooling fins your diff will run cooler. If you tow or haul anything that is a good thing. It looks great too.
Would it be worth putting on your truck? That is up to you. You don't need to re-gear to use one just pull the old cover off and put the new one on. It comes with complete installation instructions. Fill with 75w140 synthetic GL-5 gear oil and put in a bottle and a 3rd of the Ford Friction Modifier (I just put two 4 oz bottles in first and then 4 quarts of oil to put me up to the recomended level.
