Sorry to jump in here, but I have a related question. I just ordered a 55w hi/lo kit and a 35w kit for my fogs. After reading this, I'm guessing I need to get this relay kit as well, and I'm guessing I would need one relay kit per hid kit,one for the heads and one for the fogs?
Edge Programmer, Gotts Mod, CherrybombExtreme w/ duals behind wheels,
L-Heads/Corners w/ 6000k HID, Euro Fogs w/ 6000k HID,
6" Fabtech Lift 5100/5150 Bilstein Shocks BDS 5" Leafs
17x9 Helo Maxx6 35x12.50 BFG AT/KO
built by me...and you...if you post @ F150online.com
ok thanks, so i woundering i ordered the low beam hid kit and was woundering can i get just the hi/low beam bulb and wire it up to the kit i bought for just low beam. or would i need all new ballasts
yeah that seems to be correct. on ddm's site i looked at some frequently asked questions thing about the hi/lo bulbs and they say that an additional wire is required to be hooked up and that this new wire is included in a new cable with the hi/lo bulbs. so these new bulbs should come with a new wire that runs from the headlight socket to the bulb somewhere and the way mine is this new wire has a small almost telephone cable looking plug on it that plugs into the new hi/lo bulbs and this cable sends a signal that moves the magnet in the new bulb to change the position of the beam when you switch from high to low and visa versa. here is where i got this from.
Quote:
yep you would need one relay per kit. so one relay for the fogs and one for the headlights. so two in all.
6in. Fabtech, 3in. body, 38in. toyo opencountry m/t, 20in. moto metal 909, straight pipped exhaust, edge evo programmer, 2 12in kicker cvr's, 750.1 kicker amp, streetglow, bushwacker flares, westin bull and step bars, hella 500 lights in grill, piaa 510's in fogs, 6000k hid's in all lights, black heads and tails, t-rex black billet grill, custom fx4 monster stickers, black badges, train horns
so r u sayin i can order just the bulb for hi/low or a new kit for the hi/low? im kinda lost and will it make a diffenence in the f150 stock headlight housing
according to the site all you have to do is buy the new bulb and everything else is included with it.
my high beam certainly makes a difference on my truck in the stock housings, but my kit is from xenonlink.com so idk. they appear to use the same technology in the high and low beam, a little magnet that moves the beam so you should be about the same as mine.
ok thanks, i think im going to order another kit for my fog lights and order the high and low beam bulbs for my headlights, and i would need a relay harness for both fogs and heads right?
__________________ 08 f150, 4x4, stonegreen, westin bumper, 2.5" leveling kit, tint, fire and ice lightbar, backup lights,
