Overall picture with stripe removed. I used all duplicolor products starting with filler primer then ending with crystal clear. New wheels next month along with getting my front windows tinted.
the paint looks like a perfect match in the pics. is it the e4 paint code? also, did you take the door handle apart to paint it or put painted covers on?
Neither, painted them right on the truck. If you know how to tape and mask good then you can get away with it. Just gotta be able to get in those angles without spraying to much. But overall I had no problems and would do it exactly the same next time. Seems the most important part is when you do your original sanding the more time you take then the easier the rest is. So as usual the most important part of painting is the prep work. And yes it is E4, the duplicolor name is "cardinal red" and requires the clear coat to make it match.
Thanks Watson91 at S-FX
PTM Century Tonneau
Remote Start 14" si/do Magnaflow 45'd behind rear tires
4" x 18" SS Tips
Roush Grille
Billet Bumper Grille
PTM Mirror caps
DVW Intake w/ K&N drop in
Quote:
Originally Posted by 05RedFX4
Best of luck to you, and hopefully you don't have the same attitude when you go into the dealer to get your trans fixed, because if you do your gonna need a big jar of vaseline cause they are gonna stick it to you, HARD
07 Lariat 2wd 5.4....S&B Cold Air, Gryphon programmer, Harley heads, tinted tails and third, Hadley train horns, magellan nav, audiobahn 10's, LA 800w amp, Magnaflow 16616, FX2 Lower valence, 5000k HIDs, black low-pro tool box and a baseball bat in behind my seat for any dissagreements...
That's a good site az. My older brother uses that with good results
John
PTM Century Tonneau
4" x 18" SS Tips
Roush Grille
PTM Mirror caps
Great job! The Krylon Fusion works great for white. I've done my mirrors already but haven't had time yet to do the handles. Definately gonna get those and the tailgate done before the end of the year.
I used automotivetouchup.com paint for my grill surround ... it matched pretty well, considering I was trying to match 10 yr. old paint. It took numerous coats to get even coverage. I was really concerned about running out of paint, seeing how it took 2 weeks to get the paint from them.
