F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Appearance Products
Thread Tools Display Modes
  #31
Old 10-21-2009, 06:09 PM
Vehicle: 2008 Ford F150
Quote:
Originally Posted by XPerties View Post
^^^ Yep it's a 4mm, tiny little bugger. Don't try a socket, it won't fit around it. You have to use a 4mm wrench and as cstanek said it gives a detailed diagram and explanation on how to adjust your headlights in the manual.
ok thanks and after u adjust them are u still able to see far out, as in further then u could with the regular lights
  #32
Old 10-21-2009, 07:41 PM
Vehicle: 2005 Ford F150
Quote:
Oh yes absolutely. You have to remember that HID's are like having the sun right behind you so that crappy yellow bulbs that we have gotten use to is no longer. You will be happy and if your not sure about the adjustment of the headlights just drive around town and see if you are blinding anyone from the rear. If you are then adjust them again and go driving around etc etc.
  #33
Old 10-21-2009, 07:52 PM
Vehicle: 2006 Ford F-150
Quote:
Originally Posted by razerok1 View Post
not all hids come in a projector headlights 98-2003 acura tls come equiped with hid lights in a standard housing.. no all hids are not illegal the colors are whats not allowed as long as you have "white" hids id say anything under 6000K you should be fine most officers will hold a white flash card to the head light to see what color appears on the card if its still white your good if its blue purple or pink your in trouble..
heres a letter from the nhtsa about
"defines white by blue, yellow, green, red, and purple boundaries within a chromaticity diagram. Thus, it is possible to design a headlamp that emits a light that approaches the blue boundary and is perceived as having a blue tint but which nevertheless remains within the boundaries that define "white." These headlamps would comply with the color requirements of Standard No. 108. Without an actual test of your client's headlamp bulbs, it is not possible to say whether the color emitted remains within the boundaries of "white.""
http://www.nhtsa.dot.gov/cars/rules/...21118.ztv.html
im sorry but you are wrong. all hid kits are illegal whether they be yellow or purple they are illegal because they are not DOT approved and thus cannot be on the road. if an hid company tells you that they are DOT approved they are lying
6in. Fabtech, 3in. body, 38in. toyo opencountry m/t, 20in. moto metal 909, straight pipped exhaust, edge evo programmer, 2 12in kicker cvr's, 750.1 kicker amp, streetglow, bushwacker flares, westin bull and step bars, hella 500 lights in grill, piaa 510's in fogs, 6000k hid's in all lights, black heads and tails, t-rex black billet grill, custom fx4 monster stickers, black badges, train horns
  #34
Old 10-21-2009, 11:30 PM
yea ill do that thanks, yea i just order them today so they should be in, in a bout a week, i cant wait
08 f150, 4x4, stonegreen, westin bumper, 2.5" leveling kit, tint, fire and ice lightbar, backup lights,
  #35
Old 10-28-2009, 11:53 PM
so i got the lights installed today and i only got the low beam and i wish i would have gotten the hi beam, could i get the low and hi beam bulbs and hook them up to the hardness i got for just the low beam or would i have to get all new everything???
  #36
Old 10-29-2009, 12:01 AM
Vehicle: 1998 Ford F-150
depends on the company some use 4 ballasts for the bi-xenon kits and others use a bulb that moves when you turn on your highs and only two ballasts
thanks dirtyd88 for the sig
98' Extended Cab Blue/Blackout
rebuilt 4.2, 5 speed, "Gotts" intake mod, K&N Drop in,
Rhino-lined Rockers and bumpers and N-Fab Prerunner light bar with Hella 500 Lights
1.5" daystar leveling kit
Dynomax Bullet exhaust
285/75R16 BFG KO's
Pioneer premier sound system with 2 Kicker 10's, CB w/PA.......
Transformation Thread
  #37
Old 10-29-2009, 12:06 AM
Quote:
i ordered mine from ddmtunning.com so would u know by that
  #38
Old 10-29-2009, 12:15 AM
from what it looks like on the site i think you can replace just the bulbs but i would definitely call first or talk to someone with their bixenon kit already
285/75R16 BFG KO's
  #39
Old 10-29-2009, 12:30 AM
yea ill call them, i hope u can just change the bulbs cause that would be alot better then buying all new stuff
  #40
Old 10-29-2009, 12:32 AM
Vehicle: 2001 Ford F-150
Send a message via AIM to dirtyd88 Send a message via MSN to dirtyd88
usually you wont need 4 ballasts to run low and high beams, unless you have separate low and high beams.
  #41
and how hot do the ballast get, cause mine were really hot after tonight so im just woundering how hot do they get
  #42
Old 10-29-2009, 12:38 AM
Quote:
some companies do use a 4 ballast set up with two on each bulb.
i looked at the bulbs on the site and they look like you can replace them.
285/75R16 BFG KO's
  #43
Old 10-29-2009, 12:51 AM
so can u tell me whats all different between the low beam kit and the hi/low beam kit, besides the bulb has a motor in it that tilts the bulb, whats all extra or differnt between the two
  #44
Old 10-29-2009, 12:55 AM
that should be the only difference. ill let dirty take this one since he actually has the kit but im pretty sure the kit he has all he did was get new bulbs on his old ballasts and now has bi-xenons.
285/75R16 BFG KO's
  #45
Old 10-29-2009, 12:58 AM
so can i order just the hi and low beam bulb and hook it up to my kit that i got for just low beams, and if so how will it hook up
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
