F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Appearance Products
Thread Tools Display Modes
Old 05-06-2009, 11:55 PM
Vehicle: 2007 Ford F150
How to Paint Black Out Badges w/ DSG Inlays (Pics)
I have had a couple of questions about how I did the black out badges, so I thought I would post a thread with a few pictures to show how I did it.
To start, I removed the front oval so I could paint it off the the truck. There are two nuts on the inside of the grille which makes it very easy to remove. Once the nuts were off, I had to push with a screw driver to get the Oval to pop out of the grille.
Front Oval Removed.
I used a Red Scotch Pad to scuff up the Oval and I painted it with Krylon Sandable Primer as a first coat. The primer was not really needed, but I wanted to see if there was a difference between using primer and not using primer. On the rest of the badges, I did not use primer and they turned out darker and smoother. I recommend skipping the primer coat.
After the primer coat, I used Krylon Fusion Satin Black to paint the Oval. Notice the final badge looks flatter in color and somewhat bumpy. Maybe I should have sanded it after the primer coat, but the rest of the badges turned out much better.
For the badges on the truck, I taped them first with narrow automotive masking tape. I was sure to get the tape behind the badges as much as possible to allow me to paint the chrome edges and to keep the paint off of the truck. I used the same red scotch pad to rough up the chrome plastic before painting them with Krylon Fusion Satin Black. I did not use a primer coat on the F150 badges or the rear Oval.
Then, I used wider tape to add the newspaper around the badges to provide better coverage for over spray. I also used the cardboard in the first picture to keep the paint from floating around.
Here are the other badges after painting them without primer. They look darker in color and smoother than the front Oval.
I bought the DSG Overlays with Flat Black letters for the front and back. As recommended, I used Windex to make them easier to install. Once they were on the truck, it was hard to get all of the kinks out of the vinyl near the curves on the side of the oval. I used a hair dryer to finally get them to adhere without popping back up on the edges. From the picture, you will see they do not line up perfectly with the curved surface and raised letters of the Oval. The DSG color is also a little lighter than the truck. However, I think they look very good and I would definitely use them again.
More on next Post...
Old 05-07-2009, 12:00 AM
The side inlays were a little harder to install because they suggested you put them on one letter at a time. I tried their method with the first side, but it took a long time to get the "5.4 Triton" letters lined up correctly. On the other side, I installed the F150 all at once and the 5.4 Triton letters all at once and it was much easier. They both turned out good in the end, but doing them together was much faster for me.
In case you missed my other post in the Wheels section, here is the truck with the badges painted and the inlays/overlays done.
KR-Texas
Old 05-07-2009, 12:14 AM
Vehicle: 2005 Ford F150
Send a message via AIM to IDNC76
looks great
Thanks to Watson91@ Screen-Fx for the sig.
Famous last words of a redneck- "Hold my beer, watch this "
Old 05-07-2009, 12:27 AM
Vehicle: 2008 Ford F150
Looks great. Great looking truck.
Old 05-07-2009, 01:02 AM
Vehicle: 2006 ford f150
very nice
  • Apperance:6" full traction, bilsteins, pro comp AAL, 37x13.5R17 toyo MTs, harley grille, westin bull bar(PTM), piaa's, pioneer d3,6,000k HIDs, viper 5900, weathertech floor mats
  • Performance:gryphon, airaid intake, 2 magnaflow hi flows #94106
  • Next mods:ptm handles, 4.88yukon gears
Old 05-07-2009, 01:34 AM
nice man...real nice did you paint your grill yourself also? I want something along that line. Not sure if to paint my honeycomb,get an fx2 ,or get one like yours.
Could the rest of the painted emblem guys chime in to see how they hold up....I'm a bit skeptical about painting chrome, even if it really is plastic...afraid it will chip and flake
Old 05-07-2009, 01:58 AM
Vehicle: 2006 Ford F150
They look great, nice job.
Thanks dirtyd88
2" AS LEVELING KIT, ATX VICE, HANKOOK MT'S, PATRIOT INLAYS, WHITE LINE-X, WET OKOLE SEAT COVERS, CUSTOME AIRBRUSH AND PAINT
Old 05-07-2009, 02:39 AM
Totally bad ass....wow!
What color is your truck?
Can you give us a link to the DSG overlays you purchased?
The overall theme, plus the wheels....wow. A unique truck. Great creative vision.
Old 05-07-2009, 08:34 AM
Vehicle: 2005 Ford F-150
Smart idea with the cardboard box to help prevent over spray. I want to do this to my truck but the over spray thing definitely stops me from doing it.
Mods: 2005 Lariat 2wd
6" Fabtech
Fabtech Steering Stabilizers
Line-X
35x12.50 18 Toyo M/t's
18" Rockstars
Access Roll up cover
K&N Drop in air filter
35% tint on fronts
5% Sun strip
Reverse Camera
Old 05-07-2009, 10:16 AM
The FX4 Luxury package comes with PTM door handles, bumpers and front grille, so I did not have to paint them myself. I was able to paint the chrome F150 badges without any problems using Krylon Fusion Satin Black. Several members on here have done the same thing, so I do not expect to have any problems with flaking.
KR-Texas
Old 05-07-2009, 10:28 AM
Thanks!!!
The truck is a 2007 Dark Shadow Gray FX4. The Oval overlays and F150 inlays are also Dark Shadow Gray (DSG) from a company in Texas called Patriot Decals. They have the different Ford truck colors available, so you can either match your truck or go with something else. I paid $40 for the overlays and inlays with shipping.
http://www.patriotdecals.com/
Click on Emblem Overlays and then Ford Overlay.
Click on Auto and then Truck for other Ford Emblems (FX4, etc.)
I also bought flat black FX4 decals for the back, but I have not decided if I am going to install them. They were $36 for both.
KR-Texas
Old 05-07-2009, 10:36 AM
Quote:
With the two layers of automotive masking tape, the newspaper covering a large section of the truck and the cardboard, I did not see over spray on the truck after washing it this weekend. The paint dissipated quickly and the cardboard kept it close to the newspaper. The whole process only took about 3-4 hours and I would definitely do it again.
I removed the running boards before painting them because I thought it would be easier to paint them off of the truck. I will post another thread on the process I used to paint the boards.
KR-Texas
Old 05-07-2009, 03:37 PM
Vehicle: 06 4x4 xlt
Man thats a sweet @ss truck
Old 05-07-2009, 11:42 PM
Vehicle: 2000 Ford F150
Send a message via AIM to menerso Send a message via MSN to menerso Send a message via Yahoo to menerso
very nice.
Old 05-08-2009, 01:33 AM
Vehicle: 2004 ford f150
Brah! awesome rig, great work with the mods.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
