L lense/HID combo???
http://cgi.ebay.com/ebaymotors/01-03...29627847QQrdZ1
Anyone have any experience with this or anything similar? How complicated is the install?
From what I see after the purchase you are on your own.
Dont do it unless you want to blind everyone you drive by...Plus you will have a greater of getting pulled over and ticketed. I would not buy HIDS unless you have projectors and those likes do not have projectors. I mean it is your call but I wouldnt reccommend it. Install is pretty simple, most HID kits are a direct plug and play system.
Alrite so i guess its between the L lense/HIDs, or JDM 1 peice projectors and JDM HID kit, or maybe some old xenarcs if i can find a pair. Anyone know what size bulb and what brightness would be best to choose for 97-03 f150s, it seems most are 9006/8000ks or 9007/8000ks, but im not sure which bulb works.
Also anybody run the HID fog/driving light kit in their valance?
So for instance a 8000k bulb is less than the stock 4100-4200k bulb, output wise? I've never seen HIDs on a truck in person, so its hard for me to judge, but definately brighter.
If you got true HIDs with ballast/igniter with a color temp to 5000k or higher will be brighter than stock halogen bulbs but have less lumens(brightness)than an eom HID color temp of 4100k which is a white light with very very little blue/purple color to them if not any color. I believe if i'm not mistaking (correct me if i'm wrong anyone) but in oem HID system the color comes from the light prism when the light passes under the cutoff plate.
Vehicles that come with them from the factory have had the housing, reflector, and lend engineered to properly disperse the HID light. A standard housing designed for a halogen bulb will, in general, scatter the light way too much. Even projectors will do that, unless they're engineered for an HID bulb.
I drive by a guy on my way to work at least twice a week that has HIDs installed in his stock Dodge Caravan housings. (at least that's what the bulbs appear to be) He gets blasted with the Daylighters every time just for blinding me, and he can't even flash me back. (Most HID replacements don't have any provision for the high beams)
If you can find a set of Xenarcs, they're worth every penny. They're engineered with a proper beam cut-off and do a great job of throwing the light down the road without blinding oncoming traffic. Very, very rarely do I get flashed, and when I do, boy do they know they were wrong LOL!!
-Joe
-Joe
-Joe
-Joe
-Joe
-Joe
-Joe
-Joe
exactly..
Hid
I WOULDN'T GO FOR THAT SET OF BALLASTS OR LAMPS..... I HAVE A 99 F 150 XLT AND AND 05 150 EXTENDED CAB FX4 BOTH WITH REAL HIDS IN THE LOW BEAMS AND FOGS AND I'M IN NY CITY. NOT 1 PROBLEM WITH COPS EITHER. THE BEST WAY TO GO ABOUT INSTALLING A SET OF HID'S IS GO ON EBAY AND DO A SEARCH WITH (XENON BALLAST'S OR HID BALLASTS) THE BEST BALLASTS TO GET ARE THE (LEXUS- KIOTO) OR (NISSAN MASU****A BALLASTS) OR HELLA. DON'T PAY MORE THEN $200 FULL BOTH BALLASTS. YOU CAN FIND BOTH BALLASTS AND LAMPS WITH THE 12V WIRING FOR $200. PHILLIPS AND OSRAM LAMPS D2R OR D2S ARE THE BEST.
IF YOU WANT SAOME PICS ON THE INSTALL AND HOW THEY LOOK LET ME KNOW
FOX540@aol.com
believe me they look incredible and work amazeing. Don't worry about blinding people, you won't be the only car or truck on the road with real xenon lights...if the bitch there jealous.
FOX540@aol.com
