Audio install. Need lots of help.
Found this amp and it comes with an amp kit too. 250w RMS per channel and my subs are 150w RMS. This should make my subs bump if the gains are set correctly right?
http://www.sonicelectronix.com/item_...ifier-Kit.html
is this a decent amp? im trying to save as much money as possible
Don't do the Crunch.
A little more info about your current setup would is needed to properly assist with equipment selections.
We know from your previous post that you have two Kicker comp subs waiting to be installed. I am going to assume they are both 4ohm single voice coils? This means you would run wire them for either a 2ohm or 8ohm load. 2ohm is your best choice with your budget.
Wiring Diagram
http://www.the12volt.com/caraudio/wo...s.asp?Q=2&I=41
If you want just an amp for the subs then, based upon two 2ohm single voice could subs each with 150 RMS and peak of 300, I would recommend a class D mono amp. I would say around 400 RMS from the amp at 2ohm would be good. You won't use all of the power any you can run the amp gains low to keep the power clean.
Here are some choices to consider just on specs alone. I can't comment on to how well they will actually perform. I would say google each one and see what others have to say.
Alpine goodness
http://www.woofersetc.com/p-6249-mrp...amplifier.aspx
Boston Acoustics-may not be enough power
http://www.woofersetc.com/p-8610-gta...amplifier.aspx
Cadence-kinda like this one
http://www.woofersetc.com/p-8048-xa4...amplifier.aspx
JBL-not much for headroom but priced right
http://www.woofersetc.com/p-9381-gt5...amplifier.aspx
Another JBL-very pretty
http://www.woofersetc.com/p-9371-gto...amplifier.aspx
JL Audio-Very Fashionable
http://www.woofersetc.com/p-8671-j2-...amplifier.aspx
Rockford Fosgate-not sure about the prime series
http://www.woofersetc.com/p-7624-r50...amplifier.aspx
Wiring Diagram
Alpine goodness
Thanks I know how to match up subs and amps, I was just asking if the Crunch was good or not since it was so cheap. I had a feeling it was too good to be true and searching later on confirmed that.
this amp should be good. 400RMS at 2 ohm, CEA-2006 compliant, and comes with an amp kit
I am sorry if I came across as talking down to you for that was not my intention.
I had a Kicker 10ZX500.1 running a single Image Dynamics ID10 and it performed very well.
Some people will hate on Kicker but I had no complaints with that amp.
Also, almost every Kicker amp will do more than rated.
With the inclusion of a wiring kit I don't think you could go wrong.
I am sorry if I came across ad talking down to you for that was not my intention.
I had a Kicker 10ZX500.1 running a single Image Dynamics ID10 and it performed very will.
I am a noob after all. Sooo so far, I have my subs already, and I have the amp picked out. I just need to order the amp and this box:
http://caraudiofactory.com/20002003-...nded-p-55.html
I have the amp and wiring, I just need to buy a box for my truck now. I want to know if I have all the wiring for the install.
speaker wire, remote wire, fuse. Since I have two subs, do I need two speaker wires? I have one but that would only hook up one sub right?
Ground, power wire, RCA cables
connectors, screws, grommets
before wire installed:
After wire installed:
Wire travels from the passenger side of engine bay to the driver side and drops down between the wheel well and then through a grommet under the cab of the truck.
Then hidden under the carpet and floor panels:
And finally pulled through hole in carpet under the driver seat:
