F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Amplifiers
Thread Tools Display Modes
Old 10-22-2009, 12:37 AM
Vehicle: 2008 Ford F150
Will a capacitor help?
I have 2 amps in the truck, one for the sub and the other for the components up front. Nothing too big, nothing fancy or crazy wattage. I just notice on some songs when the volume is up, the lights dim a little and I think my headlights flicker a tiny bit which is my main concern. Truck is completely stock electrical wise and plan on keeping it that way. I thought a capacitor might help the dimming, but i've never used on on any thing I've installed and dont know too much about them. I just need something basic, nothing fancy. What are you guys using? Tha amps are close to 500 watts each, and not turned up all the way. I just wanted a nice clear sound with a little bass to back it up. Thanks guys
Old 10-22-2009, 12:52 AM
Vehicle: 2007 Ford F150
i say no i would start off with the big three or a least two of them
1. upgrade battery ground and wire going from alternator to battery to a heavier gauge
2. upgrade battery
3. upgrade alternator
the 1st two would be the cheapest and it sound like the 3rd is out of question anyways
Caps can do some unwanted harm to your electrical
if you notice all of the big name audio gurus don't have caps they use a ton of batteries and upgraded alternators and large high grade wiring
i am running 1500 watts on my system with no cap
my battery ground and power are both 2 gauge as of now (i still have a slight light dim but still stock battery)
hope this helps
EDIT: i left the stock battery ground and bought a ground post with multipule grounds so i am runnung the 2guage with the stock ground also
thank you Watson91
4.6 281ci REPRESENT -Best 0-60 7.4 9-8-09 - but i think i can do better
*Edge Evo* Cowl Hood* 2.5" leveling kit* 17" AR Victor Rims* 285-70-17 Nitto Terra Grapplers* 18" Maggie muffler
*K&N drop in Gotts mod* Pioneer P4 HU* CerwinVega Vmax 10* Fusion 6.5" Components* keenwood AMPS
Old 10-22-2009, 12:59 AM
thanks, I did a little searching and found the "big 3" to be on alot of them. How hard is it to change out those wires? What type of wire and connectors do I need?
Old 10-22-2009, 01:08 AM
the hardest time i had was finding what size my alternator was to get a fuse to replace the one going from the alternator to the battery
as far as grounding go to and audio shop and pick up some new battery post mounts with multiple negative connections and positive connections (they come in packs of both or you can just get the negative one ) connectors just regular eye connectors will work and just find a good spot to ground to and try and make it as short as possible
how is your set up wired now ground locations and wire sizes??
thank you Watson91
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
