View Poll Results: Should Ford keep the NA base model 3.5L V6?
Yes, the F150 needs a low performance, low cost engine.
20
74.07%
No. The 2.7L EcoBoost is better in every way and it is fairly inexpensive.
7
25.93%
Voters: 27. You may not vote on this poll
Question of the Week: Should Ford kill off the base 3.5L V6?
The new 2.7L EcoBoost V6 in the 2015 Ford F150 is better than the base V6 in every way and it only adds $795 to the final price.
For our Question of the Week, we want to know whether the members here think that Ford should continue to offer the NA base model V6 or should they make the 2.7L EcoBoost the standard base model engine?
The arguments for the change for the 3.5L to the 3.7L was improvements in gas and cheaper to produce. I can't imagine that the 3.5L is really any cheaper for Ford to make than the 3.7L As for MPG, It's VERY doubtful that the 3.7L what have gotten worse mpg in the 700 # lighter trucks. They probably could have given a taller gear to the more powerful 3.7L and it would have gotten BETTER mpg than the 3.5L Stupid move by Ford.
But, I see no real need for 4 motors.
Are you just speculating this - I am pretty sure they are all the same family of engines. The only difference is that the 3.7l had a longer stroke.
http://www.ford.com/trucks/f150/specifications/engine/
http://www.fordf150.net/2014/2014-f150-tech-specs.pdf
So Ford is sacrificing a great engine to save a few bucks on a crankshaft. Not buying it. I think they just wanted more people to bump up to the 2.7tt
OK. Lets set some things straight...... the 3.5L is the Original Cyclone v6.... the 3.7 is simply a larger BORE version of it..... same stroke...... same engine..... Ford says its a new 3.5l but it seems the only thing new is its placement in the F150.....as far as the "downsizing", the only logical thing i can figure is that the 3.7 to them is too close in power to their new 2.7........ still though, the 3.5 na will still be more than enough engine to do anything a 1/2 ton truck needs to do......
Think about all the stuff everybody used to do with 6cyl trucks back in the day. Ford even offered the old 300ci I6 in 3/4 tons. 150hp and 260 ft lbs at its peak. All through a 3 or 4 speed tranny, and often not with a particularly deep rear end. And the work got done with them everyday. I bet the NA 3.5, with 6 speeds and a 3.73 axle probably still has a lot of snot to it. I have the 3.7L myself, and I have no complaints. If I was going to tow heavy on a regular basis, I'd have bought a 3/4 ton.
