The 35 gallon tank is actually a bogus option?
Old 09-25-2015, 11:28 AM
crazynip's Avatar
Looking to source a 35 gallon tank to do the swap on my 2015 I found this...
Seems to indicate the tank is the same, and they have some sort of limiting device in the tank preventing you from fully filling it up?
http://www.cleanmpg.com/forums/showthread.php?t=51614
Old 09-25-2015, 12:20 PM
fordmantpw's Avatar
I'm just glad I don't spend 2 hours topping off my tank....
Old 09-25-2015, 12:56 PM
leikos's Avatar
Pretty crazy experiment. From the schematics posted, it does look like there are 2 different tanks. My guess is that both tanks can hold more, and there must be a reason that the fill level is set where it is.
That guy needs to spend another 2 hours filling up the extended range tank to see.
Would be nice if there is an easy way to increase the capacity of either. A 1,000 mile range would be really something.
Old 09-25-2015, 07:20 PM
05RedFX4's Avatar
They have to allow for expansion of the fuel, that's why there is extra space in the tank.
Old 09-25-2015, 08:23 PM
And continual force feeding of "extra" gasoline can actually back feed into the charcoal canister. Complete liquid saturation in the vapor canistor can lead to catastrophic damage
Old 10-05-2015, 12:55 PM
mkosu04's Avatar
4 options I see:
1 - two hours in the wind with the funnel stuck in to hold open the valve = 10 gallons of gasoline evaporated into the air.
2 - he filled all the air space with gasoline. Don't let it warm up or you'll have a mess!
3 - the charcoal canister is full of 10 gallons of gas, like Patman mentioned.
4 - the pump just shut off early (we've all seen it) and he was 10 gallons short at the beginning...
Old 10-05-2015, 06:32 PM
RSTHD150's Avatar
Did this one with my sports car. Overfilled tank by 5 gallons. I ended up getting 500 miles out of my Z on one full tank. You could damage evap controller or other items such as fuel level indicator.
Quick Reply: The 35 gallon tank is actually a bogus option?
