LED Headlight conversion
Old 09-13-2015, 09:41 AM
benhull's Avatar
I have a 2015 F150 Lariat, FX4 (2.7 L) with the 501A package.
I wanted the LED headlamps but could not get the 502A package with the 2.7L (very stupid).
I was wondering if I could have a ford dealership do a full headlight assembly replace on my truck to get the factory LED lamps (the ones that come with the 502A package). With the amber outline.
Would the LED headlights, fix, have the same wiring harness, and work?
Old 09-13-2015, 09:50 AM
Boataddict's Avatar
They aren't cheap but you can get them here with the proper adapter.
http://www.raptorretrofit.com/2015-f150-headlights/
Old 09-13-2015, 02:14 PM
Mpkav's Avatar
The ones above are identical and much cheaper than getting them through ford.
Old 09-13-2015, 07:19 PM
cdiddy4224's Avatar
Not sure where you are located but I plan on having to do the same when I grab a 2016. Check out www.http://elstiggarage.com - They are located in California
Or check out: www.facebook.com/retrocustomz which are based in Florida
Both have done the new F150 headlights and do work for some dealerships.
I was quoted for single projector with the housing blacked out including full HID kit and harness at $600, and that's sending them your headlights. For dual projectors it was about 900-1000
Old 09-22-2015, 01:31 AM
lukeharper's Avatar
Have you considered aftermarket LED headlights? No need to pay big bugs and adapters at least...
Quick Reply: LED Headlight conversion
