Tire Advice Wanted
My winter set of wheels/tires is just one size taller & wider than the stock set. My roads are all 55mph hill and turns here in the mountains and the transmission is always shifting between 5th & 6th. Doesn't do it nearly as much as the stock size tires/wheels.
So yes - tire size can definitely affect your truck's shifting.
You can try and do a KAM reset to see if that helps the tranny re-learn it's shifting strategy. Just disconnect you battery and turn the headlights on. Shut off the lights and reconnect the battery after 15 minutes.
There are also a few TSB's out for that year in regards to tranny issues. Mostly hard shifts, but may be worth investigating.
I agree with the others that larger tires can also have an effect on the shifting.
