Heated mirrors
I don't have one but I've been told that the rear window heaters are in series with the side mirror heaters therefore you can't simply bypass the rear heater without overloading the side heaters. You would need to bypass the rear heater through a large resistor or other device to drop the voltage to the side heaters. You're not the first one to have this problem and it would be nice is someone would measure the current through the heaters and the voltage across each one then we could find a suitable bypass.
