Ecoboost moaning while under load
Just joined for your message. My son-in laws F150 has a similar sound with loss of power. History of this is last month he had the death rattle of the timing chain. Ford wanted 7K to replace so I did it for him with 1K worth of parts and 5 days in the garage. after all that no codes for a week. then he got a low oil light and not being mechanically minded he added 2 quarts of oil without checking the dipstick. He came back with 7 codes all due to the oil foaming up Ithink. Told him to get the oil changed so it would be emptyed and refilled to proper level. After that he cam back with one code, the PO299 "under boost" code. following many Youtube suggestions I cahnged the Blow off valve. Code cleared and ot ran good for a day. Code came back and it started to sound like yours, around 1500 rpm, under load. I have chaecked the exhaust manifold bolts, the three sensor on the intake tubes. the sound is loader on the passenger side, so I checked that turbo for the waste gate and the fins for end play and free spinning. I am going over all the hot and cold side tubes now. still scratching my head trying to figure this out. If I find something I'll let you know and would you do the same?! Hope its not the turbo!
