Telecsoping steering column?
Yes, on my 2014 there is a lever on the side of the column that locks it into position. If you release the lever you can manually tilt or extend/retract the steering column.
My 2011 had tilt but not the telescoping feature.
I also have the adjustable pedals. The button is on the side of the column right next to the tilt/telescoping lever. I'll see if I can get a measurement a little later.
I finally got a measurement. I wasn't really sure how to measure so here's my attempt....There is a bezel that surrounds the gauge cluster. On the bottom the bezel extends out about .5" beyond the clear lens. I measured from the bezel to where the horn button starts. With the tilt all the way up and the column telescoped all the way up I got 8 5/8"... See pic >>> https://www.f150online.com/g/picture/5514829
So if the measurement placement looks like what you did. I'm seeing 7.5 on my end.
So 1" further difference between telescope and fixed. (I imagine your travel is 6.5 to 8.5)
