2-piece driveshaft carrier bearing drop for 3" block?
If I install 3" lift blocks with an '09 2-piece driveshaft 4X4 is it neccessary or recommended to shim the carrier bearing bracket downwards?
I read that the 4x4 has 1.25" factory blocks, so this will add 1.75". I also read that the recommendation is 1/4" bearing drop per 1" lift, so 7/16" shim for the bearing?
Has anyone installed 3" blocks on a 2-piece driveshaft setup and not shimmed the carrier bearing bracket?
