35's dont fit and must trim metal. What is safe? Need help ASAP.
Just got back from the tire store, my Nitto 35/12.50/20's dont fit on my Jester rims with +12mm offset. So, Im gonna have to trim or downsize to a 305/55/20. I have attached photos of the metal that has to be trimmed. The first pic shows where it rubbed, on that little part that sticks out. The outside of the tire BARELY kissed that plastic so minimal trimming would be needed on the metal. I think the line I drew would be what would have to be trimmed.
ORRRR
I could go with a 305/55/20. Im not sure how different it would look.
ORRRR
Im having trouble spending $100 more on a 295 sized tire, much a less a lift. Im going back tomorrow to set whats gonna fit. I took off that back black thing (not sure the name) so we can see how the 35's rub. If its minimal, im gonna grind it cause the 295's are more money. I can always hide the grind behind the plastic. I think 295/65 would work cause the 12.50 barely touched the black so a tire that is 1in narrower would clear.
I also believe it's just dirt. If you open that area up it'll be completely FILLED with dirt, leaves and other debris that falls down through the cowling. I recently cleaned that area for the first time and was shocked with how much stuff came out.
