Camper Shell Brake Light Question
Are you talking about hooking the light to the brake light system in a 2014 F150? I wonder if a 2104 F150 will even have brake lights?
I'm pretty sure mine is simply connected directly to the brake light circuit at the rear of the truck. If the light is an LED, it can certainly be connected there. There's no reason to run a wire all the way to the engine compartment.
Now, if you're talking about the bed illumination light, I DO have mine connected directly to the battery (through a fuse) so I can turn it on any time (ignition on or off).
- Jack
- Jack
I'd have to crawl under the truck and inspect the wiring to find out how the light is connected. But, my 3rd brake light in the cap is NOT on when the headlights are on or even when the flashers are on. It only comes on when the brakes are applied.
I don't think my light would even support the dual circuit that the running/brake lights need to function on dim and bright. It's an A.R.E. cap, with a built-in LED brake light. There are only two wires to it - hot and ground.
If you pull a taillight housing out of the bed, you should be able to tell which wire is hot when the brakes are applied. Simply attach your 3rd brake light hot lead to that one.
- Jack
- Jack
- Jack
