Re: How to Manually Close Sunroof/Moonroof in Tilt Position in 2009 F150
The information by windproof in "Neat Way to Manually Close F150 Sunroof" using the 5/32" allen wrench into the gearbox after taking down the headliner is very helpful. However, my sunroof/moonroof is stuck open in the tilt position.
When I turned the allen wrench several times in the gearbox, nothing happened. I realized that this discussion was about a sunroof/moonroof that was open. What about a sunroof in the tilt position? Can it be cranked closed using the allen wrench in the gearbox method? If so, which way do you turn it (clockwise or counterclockwise) and about how many times around will it need to be turned? Thanks!
lbodkin
2009 F150 5.4L V8 Supercrew Platinum 4x4
lbodkin
