Positive or negative offset on leveled F150.
Well, after many hours of research, I have concluded that 35in tires will fit my truck and with that, I am upgrading to larger rims. I just read all of Davids build post for his F150 http://www.f150forum.com/f78/my-plat...-build-202641/ and I fell in love with that truck.
I love the look of the red on silver and want to match that to my truck. Now, with these rims (http://www.autoanything.com/wheels-r...-jester-wheels), I can go either 12 or -12 on the offset. To my knowledge, the negative offset pokes the tire out farther correct? Well I love the look he got with the -12 offset but im worried about the trimming. How much is required for this? I know for the positive offset it is minimal, but im not sure about the negative.
Would this just require some plastic trimming or would an angle grinder be needed?
Yes -the negative offset pushes the wheel out further. You are talking about 1" between the -12 and +12. Mine are +20 and you can see they are further in than David's
I had to do minor trimming but just of the plastic. I think you will have more trouble with the height, but the negative offset should help.
