Added illuminated visors 2014 STX
My 2014 STX came with plane jane visors. Driver side no mirror, Passenger side mirror but no illumination
I ordered two visors from my local Ford dealer
CL3Z.1504105.EC $43.18 list price
CL3Z.1504104.DC $38.87 list price
Matching L&R Grey with mirror with illumination
I was happy to find out my truck was prewired for it.
drivers side comparison
passenger side harness is inside the headliner above the visor, parallel to the windshield
drivers side is parallel to the door opening
I removed the plastic clip out of the roof to show how the harness is supposed to be routed. You'll notice a slight valley cut out in the white clip to allow the harness to pass through the side without getting pinched
and voilla!
and voilla!
You should have got the one with the garage door opener built in, they just need power and ground to operate. They are required to not integrate them into the can bus so they are basically plug n play. It's a pretty common swap on the mark 3 focus' the 2012 had it factory installed then it was dropped for 13 and 14 so everyone without it just buys a 2012 visor and swaps it in. On the focus model the power and ground are spliced into the same wires that power the mirror inside the visor so they use the same plug under the headliner.
