Sponsored by: DashLynx
Best Fuel Mileage Tire?
Old 03-03-2015, 10:21 PM
Hereford F150's Avatar
What are your opinions regarding fuel mileage oriented tires? Is there another tire that will match or beat the Michelin? If so, will they match the longevity?
Old 03-03-2015, 10:41 PM
It will be hard to find a better tire than a Michelin..
Old 03-04-2015, 11:52 AM
That's what I'm thinking...
Old 03-04-2015, 12:01 PM
MCDavis's Avatar
The LTX M/S2 is tough to beat for what it is. Their Latitude tire is supposed to be even better in regards to rolling resistance.
The HT tire from Cooper seems to do well also.
Old 03-04-2015, 12:41 PM
Roadie's Avatar
I gave up on cheap tires years ago and buy Michelin almost exclusively. They always run smooth and quiet for a very long time. When they get several years old the rubber hardens to the point I notice a difference in traction. I have the Michelin P tires on my truck and they have about 42k miles on them and look to be good for 20k or 30k more. I usually buy from Sam's club and take advantage of their free rotation and balancing for the life of the tire which has to help in the smooth quiet running and probably helps the front end components to last longer.
Old 03-04-2015, 01:56 PM
I Already have 57k and change on the Michelins I have. Probably good for another 15-20k. Have one that has a sidewall repair that may not last much longer. My brother gets 90k out of Michelins on Ford trucks, but I tow much more often, have more city driving. I have the LTX A/S
Old 03-05-2015, 12:46 AM
glc is offline
I've got about 90k on a set of BFG Long Trail TA's on mine, and they still have some life left in them. A lot cheaper then Michelins, but they don't make them any more. I hear the replacement isn't near as good.
Old 03-05-2015, 09:23 AM
Roadie's Avatar
Michelin owns BFGoodrich now. So maybe they are better tires than they used to be.
Old 03-06-2015, 04:29 AM
Need4racin's Avatar
least aggressive tread for sure. But kinda defeats a truck when you get stuck in wet grass though doesn't it.
Old 03-06-2015, 09:12 AM
MCDavis's Avatar
I've had good results with the M/S2 off pavement. The hunting lease is fireroad after fireroad and I didn't sink her with those tires. Now, they aren't as confidence inspiring as a hefty AT or MT, but they didn't leave me walking.
My next tire choice will be tough...love the looks of the new KO2 but the everyday performance of the M/S2 is hard to beat. I'll also be going up to a 275/65/20 so weight is a factor also. The M/S2 are considerably lighter than other tires in the same sizes, by as much a 5-8lbs per tire.
Old 03-07-2015, 12:01 AM
Roadie's Avatar
4x4 with traction lock rear in my case so no worries. The only time my truck goes off road is on the beach and the less tread the tires have the better on sand. You want to stay on top of the sand not dig in. I usually let a little air out to help stay on top.
Old 03-13-2015, 07:38 AM
cardboard's Avatar
So Nobody likes the Goodyear Wrangler tires that comes on the truck ?
Old 03-13-2015, 11:00 AM
Wookie's Avatar
Utter crap! I wouldn't put a set on my truck if they were given to me.
Old 03-13-2015, 12:23 PM
cardboard's Avatar
So you are not gonna say what is wrong with them.
Old 03-13-2015, 12:26 PM
Roadie's Avatar
I bought a new 2000 f150Scab4x4XLT that had the Wranglers. They were the longest wearing tires I've ever had on anything. They would have lasted about 120k miles except the sidewalls started cracking. At 72k, I replaced the first two because they cracked 360 degrees at the sidewall bulge on both sides to the point one was losing air. at about 92k miles I replaced the other two. I almost never used 4 wheel drive so I wasn't too worried about the new/old combination. So, yeah they lasted a very long time. But, I'm still puzzled by the sidewall cracking issue.
Quick Reply: Best Fuel Mileage Tire?
