Mod pic-got rid of the coin holder
Yep. In the event that you have 2 smallish and 3 medium-large coins in your possession and they just won’t fit in your pocket or maybe you need them handy for say a toll booth, then that is the feature for you. Otherwise, it’s useless. The guy who came up with that idea probably got a raise too.
I run battery line and switched power line from the fuse box.There is switched power in the connector,but must be going thru some resistor-has around 1v less.
The ground is in the connector behind the coin holder.
Got the meter from ebay.
Had to cut some plastic around the hole with the dremel.
