Lifted f150 wheel as tire selection
So I just purchased a 6 inch rough country lift and it should be in the mail in a few days. I now need to select wheels and tires for my truck. I have narrowed it down to 18 inch method mesh wheels wrapped in 35 inch nitto trail grapplers. I like the look of the tired poping out last the wheel wells( about an inch and a half or 2). I'm trying to figure out what offset/backs pacing I should go with in order to achieve this. Any input would be appreciated. Thanks!
Might be tucked in a little, but I think the backspacing would still be too high to be compatible with your lift kit. Pretty sure Rough Country calls for a wheel with 4.5-5" of backspacing.
Method does make the wheels with the correct backspacing you'd need just with the wrong bolt pattern. So you might want to try calling them and see if they'll drill the 6x135mm pattern onto one of the other wheels.
