Bumper winches for your truck
If you have ever been on the trails pulling yourself back on your feet, you understand that the most important factor about tough situations is getting out of them faster. Winches are made for guys, who seem to always swerve towards the closest mud hole. We offer both hydraulic- and electric-powered winches in all sizes and designs to fill any winching need from 2,500 pounds of pulling power up to almost 20,000 pounds. Winches we sell are equipped with multiple gears that make the most out of each unit's ability and allow pulling at slower speeds when more control is needed or at faster speeds when rapid pulling is best. To learn more you can visit Winches section at CARiD.com.
Rugged Ridge® - Off Road Winch 8500 lbs http://www.carid.com/rugged-ridge-wi...s-4430903.html
Features:
- Durable 5.5 HP series wound motor
- Tough 3-stage planetary gear box with 172.8:1 gear ratio
- Durable 12' all weather cable remote solenoid box
- HD steel cable winch includes 94' of 5/16" diameter wire rope and latched hook
- Performance synthetic rope winch includes 100' of 11/32" 12-strand braid synthetic rope with a breaking force of 16, 550 lbs.
Mile Marker® - Electric Winch 15000 lbs http://www.carid.com/mile-marker-win...s-3621165.html
Features:
- 15,000 pound load rating
- 79 feet of 10-millimeter thick aircraft grade cable winding
- 5.5 horsepower
- Weighs only 101 pounds (25% lighter than competitors)
- 12-inch wired remote control allows operation from a safe distance
- 3-stage planetary gear set design
T-Max® - Performance Series Winch PEW-9500 http://www.carid.com/t-max-winches/t...ch-437475.html
Features:
- Rated Line Pull: 9500 lbs Single Line
- 6.6 hp 12V Series Wound Motor
- Gear Ratio: 218:1
- Weight 77 Lbs
- Overall Dimensions (L x W x H) 21.2" x 6.3" x 8.6"
- Mounting Bolt Pattern: 10.00” ± 0.015” x 4.50” ± 0.010”
WARN® - 12000 lbs 12V DC ZEON™ 12 Electric Winch http://www.carid.com/warn-winches/wa...-12515677.html
Features:
- 12,000 lb. single line pulling capacity
- Line speed: 30’ per minute under no load and 3.1’ per minute at 12,000 lb. max. load
- Fast and reliable 3-stage planetary gear train with 216:1 gear ratio
- Dimensions: Integrated configuration – 24.25”L x 7.15”D x 10.52”H, Low-profile configuration – 24.25”L x 7.15”D x 7.84”H
- Weight: 98 lbs.
Also you can check installation video here:
What do you think about them?
Features:
Features:
- 5.5 horsepower
Features:
- Gear Ratio: 218:1
- Weight 77 Lbs
Features:
- Weight: 98 lbs.
WoodsTruck, yes, it should be possible. You just need to find specific mounting kit for your model. Share with us the results, I am curious to see how it works!
joe51, you can check the prices on our website, or call to our general sales line and guys will gladly assist you. It might vary depending on your year/make/model and zip-code. If you mention that you are a fist time buyer and also a forum member, they will definitely provide you with the discount.
I've been seriously thinking of doing that. I don't do a lot of off roading in my F-150 so I don't need or want to carry a winch around all the time. Also being able to pull from the rear as well as the front could be a huge advantage. My biggest concern is the weight of winch and cradle! Together you're looking at about 120 lbs and that's a lot of weight to be wrestling with in the mud. My knees are not as young as I once was and now they'd have a difficult time managing that even in good conditions. And it's not just an issue of moving it around but also picking it up and holding it in the air while trying to get the cradle tube into the receiver tube.
Anyone here have any experience with it? I'm thinking that grinding a 45d taper on both parts may help it go together easier. Thoughts or suggestions?
