2012 FX4 - Service Advancetrac
#61
Well, the truck went in yesterday. The good news is they are repairing it under warranty. The bad news is they needed to order the part (complete column). They also needed approval from Ford and needed to order some sort of tool to do the job. At least this is what they are telling me.
At first he told me the turn signal unit was bad. I told him of my research on the failure and he went back to work more. He came back about 1/2 hour later and told me after looking at the fault codes, the complete column had to be replaced.
I Don't have my truck back but they are treating me quite well and I have no complaints about the service (yet). lol
Crystal
#62
#63
Crystal
#64
I got my truck back and all is well. They fixed it at no charge. However, they did a poor job of aligning the front-end. Driving straight with no hands on the wheel and my steering wheel is about 4 degrees to the right. I straighten it to center and my truck turns left. I called them and he said to bring it in for an alignment. We'll see if they charge me for the alignment. It was straight as an arrow before the repair.
Update: They did the re-alignment for free and apologized for the poor job. The guy said that it wasn't normal for them to do an alignment and not check the steering wheel position. It slipped through the cracks. All is good... Back on the road again.
#66
Crystal
#68
I'd recommend making an appointment at your local Ford Dealership so they can take a look. If you need help finding a dealer near you, just enter your ZIP code here: http://www.ford.com/dealerships/locate Once they've checked things out, I'll be able to investigate ways to help.
Crystal
#69
F150 Codes U 0428 and C1B00
I have had the same issue with my 2012 F 150 it is at 37000 miles and it has been having the service advanced track light come on for a little while and the turn signals will not work. Also around this time my rear drivers door lock stopped working. I took it in they say I had the following codes U0428-20 - Invalid data received from steering angle sensor module and C1B00:62-48-PSCM- Steering angle sensor. They said new EPAS gear need s to be installed. They looked at the door lock and sais the wires are frayed and so the door harness is broken. So 1,000 miles out of warranty and 2,000 bucks in repairs? I believe this should be a recall item. I have now heard from many f-150 owners this is an issue. I have yet to fix either of these items, probably because I am a little upset about both issues. I have never had a vehicle have a problem this early in life, I am very worried.
#70
I have had the same issue with my 2012 F 150 it is at 37000 miles and it has been having the service advanced track light come on for a little while and the turn signals will not work. Also around this time my rear drivers door lock stopped working. I took it in they say I had the following codes U0428-20 - Invalid data received from steering angle sensor module and C1B00:62-48-PSCM- Steering angle sensor. They said new EPAS gear need s to be installed. They looked at the door lock and sais the wires are frayed and so the door harness is broken. So 1,000 miles out of warranty and 2,000 bucks in repairs?...
Crystal
#71
Its running great since the last repair and, overall, I really like it. But, I have lost a significant amount of faith and trust in it. Hopefully, henceforth all will go well. However, it wouldn't take much more of these "malfunctions" happening for me to seriously start exploring my non-Ford options.
#72
I just bought my truck 4 days ago, used..and now I am having this EXACT same problem...go in reverse, make a sharp turn, Advancetrac warning comes up and signals do not work...I didn't buy the extra warranty now im SOL...what on Earth should I do.......................very very very frustrated
#73
Crystal
#75
Crystal
