Sliding Rear Window defog contacts
Have you been to your dealership for diagnosis, Maverick 15? How many miles are on your truck? I'll do all I can to assist.
It sounds like things are headed in the right direction, 05RedFX4; I'll look forward to reading your updates. What's the current mileage on the truck?
Crystal
Crystal
Thanks for the quick reply, 05RedFX4. If you need me to step in and help, just send over your specifics in a PM. When writing, be sure to include your full name, best daytime phone number, VIN, current mileage, and servicing dealership. I'll loop in your regional customer service manager (CSM) and have them give you a call.
Crystal
Crystal
They called me around 1 pm and said my truck was done. I looked it over the best I could considering it was rainy and gloomy today, and it looked OK, did not see any globs of window sealant anywhere, especially on the leather seats. As far as I could tell they did a professional job and cleaned up after themselves. And the rear defrost works. The inside of the back glass center section looks different from the old one, my guess, ford redesigned and/or revised the window assembly to try to reduce the failure rate.
Crystal
New parts?
Umm, Crystal? I've been dealing with a faulty rear defroster for some time now, hesitant to have the dealer repair it (even under warranty) for fear of just getting the same part. Can you confirm there is an upgraded slider w/defrost available?
And also, now that my truck is two weeks past warranty expiration, will Ford accommodate me with a repair, at least to some degree?
Thanks,
Mark [012XLT50]
...The inside of the back glass center section looks different from the old one..
Thanks,
Mark [012XLT50]
Thanks,
Mark [012XLT50]
I don't have access to information that would tell me if a part has been redesigned or not; the best resource for that info is the service manager at your local dealership. They'll also be able to tell you if a repair can be made under warranty. How many miles are on your truck? I'll be happy to look into ways to assist from my neck of the woods.
Crystal
Hi Mark,
Crystal
Crystal
The truck has about 22,000 miles and I made an appointment for next Tuesday, 11/17 for evaluation.
Crystal
Crystal
