Upper Ball Joints 2009
Just had my state inspection done today - state inspection is annual in Penna.
Passenger side upper ball joint bad at 47K miles. Had the driver side go bad at 38K miles (just out of warranty).
Is this a known problem for this series F-150? Mine is an Fx4 crew cab with 20" factory wheels.
My truck is bone stock - have never touched anything. I just find it kind of weird that both these ball joints went bad so early. Can I look forward to these $240 bills every 30K or so miles? Heck I am still on the factory tires and brakes!
Factory ball joints tend not to last too long. 35-60k is about average with some people stretching them out to around 80k. Biggest flaw is they aren't greasable, greasable ones when maintained can last a whole lot longer than the oem ones. As for length of how long until you replace them again, it depends on the quality of the ones you went with and other factors like driving style, maintence of them, and your alignment.
Factory ball joints tend not to last too long. 35-60k is about average with some people stretching them out to around 80k. Biggest flaw is they aren't greasable, greasable ones when maintained can last a whole lot longer than the oem ones. As for length of how long until you replace them again, it depends on the quality of the ones you went with and other factors like driving style, maintenance of them, and your alignment.
I am thinking these are wearing so quickly because of the roads around here. I'm in the boonies and the roads (paved) are rough and have lots of ruts in them. As you go down the road your truck or car is constantly pitching back and forth and you are constantly re-correcting. I guess if I was on interstate type roads all the time they would last a lot longer.
After 5 years of ownership, this is the only thing I've had to have replaced. Not so bad I guess.
None whatsoever both times. Even after the replacement I feel no difference at all.
No. The truck is bone stock except for a tonneau cover and bed liner.
Both times I was told the ball joints have wear/movement beyond the rated spec. I just did a search but can't find the specific measurement. This is a requirement for Pennsylvania state inspection.
Wonder how they check said specs... Hmm I live in PA and around here they don't check much before slapping the sticker on the vehicle.
I watched the local guy do it. He raises the front of the truck so the front tire is ~2" off the floor. Then takes a pry bar under the tire and lifts up on it. Real easy to see any movement in the ball joints that way. If need be he will then measure the amount the ball joint moves.
http://corporate.ford.com/owner-serv...d%3Dsuggested1
http://www.autonews.com/article/2013...parts-warranty
