Replacement key help!
Well...got the chipped key i ordered off ebay. I got it cut n so far no luck programming it. I followed manual n nothing.
I have 1 ford key that came with it n 1 i got cut n programmed at true value. Truck computer says i have 3 admin keys programmed. I am assuming its the ford key i have, true value key, n 1 the previous owner prob lost.
Any thoughts??
Any thoughts??
Have all three keys together.
You need to do this rather quickly because it times out after like 10 seconds.
Take one of the already programmed keys and put it in the ignition. Turn the key to the on position (all the way forward but not far enough to turn the starter) and then turn it off and remove the key. Do the same process with the second already programmed key. Now take the key that needs programmed and put it in the ignition. Turn it forward like the other two but don't turn it right back off. Wait until the anti-theft light shuts off. the trun ignition off and the 3rd key should be programmed.
When you do the key cycle with the two programmed keys try leaving the ignition on until the anti-theft light goes out before changing keys. Do that with all 3 keys
I asked our head shop tech. He thinks it's the wrong key or it has a bad chip in it. The process I talked about and you've already gone through is the proper way to program the key. There is a limit to total amount of keys that can be programmed but with a 2010 truck I would doubt that's the case. I forget the number but it's like 10 keys
Any thoughts??
Any thoughts??
