Best reverse light bulbs
3rd car I've had them in, no issues whatsoever. They are a 15 watt HID bulb WAY brighter than anything else out there. Not sure why you'd think they would overheat..Have you owned a set that over heated and burned out the socket? I'd be curious to hear about your experience.
An HID actually draws less current than a halogen bulb, so it is unlikely that wires would just "burn up" from a proper install. The trucks factory fog light fuse should have stopped that. My guess would be the bulbs were improperly installed and that contact from the bulbs damaged the wires....
The kit I'm talking about are a 15 watt kit made for back up lights.
