High beams AND Fog lamps
I have a '10 Platinum and as with my '05, when I put on the high beams the fog lamps go out.
I appreciate why Ford has set the lights up to be like that ie. if youre in fog you shouldnt need the high beams so if you need high beams you probably dont need the fog lamps HOWEVER when we are out in the desert and its dark I want all the light I can get, any ideas how this is possible?
Im not looking to add spot lights and a bull bar etc etc - I'm just looking to maximize the light I have at the moment.
Well its true you would maximize light output, but realistically it would hurt you to have fog lights lit up in conjunction with the high beams. The fog lights make your eyes focus on the road in front of you, and making you temporarily near-sighted, and this works against the high-beam.
OP- the best bet for you is to wire them separately. But if you think this is going to help, as a person with fogs on a separate switch, I can tell you it doesnt. When my high beams are on I manually reach over and turn off my fog lights, they mess with your down the road sight that bad.
It was a dumb, ill-considered (and acuity-impacting) mod back in 2011 when this thread was born.
Nothing has changed - it's STILL a dumb idea.
However - you may as well learn to use the site's Search feature from the get-go and search for 'Bambi Mod', if you wanted to proceed regardless of what common sense tells you.
Best of luck.
fog lamps on with high beams
I purchased kit this on eBay for $24.00 free shipping. Wished I would of looked there before I spent hours searching.
http://www.ebay.com/itm/FORD-F150-Truck-HIGH-BEAM-FOG-LIGHT-KIT-Turns-Fogs-Back-On-W-High-Beam-Lights-/150552955416?pt=Motors_Car_Truck_Parts_Accessories&hash=item230da7ca18&vxp=mtr
good luck.:
good luck.:
Ford didn't set up the light because you don't need high-beams in the fog, its because they work against each other.
Your high beams arent four beams. Its two. The H13 is a dual-filament bulb. You can have either the lows on or the highs. Not both. And see above as the reason why they are made to disengage.
Did ya miss it?
http://www.sylvania.com/en-us/applic...artnumber=9007
H13:
http://www.sylvania.com/en-us/applic...partnumber=H13
Now - if you are referring to retrofits, then yes indeed.
BSB
You are correct but what most people don't understand is that each high beam counts as two bulbs per the Feds no matter how many filaments are being used. That means with the fogs and high beams on a total of 6 bulbs are lit. Now, I doubt many cops will stop you for this since they don't enforce the lighting laws very well. Drop in HIDs I'm looking at you!!!
