Raptor e-locker in 2hi mod on e-locking rear diff trucks
#92
- BL3Z7E453D (TM-239): TCCM that is stock on 2011 Raptor, members have it working on 2011 F150's
- CL3Z7E453CD (TM-261): TCCM that is stock on 2012 F150 with ELD, one member on the other F150 forum has it working on his 2011 F150.
TM-243?
I don't think anyone has tried that yet.
CL3Z7E453DA (TM-243): With Electric Transfer Case ; Electronic Locking Differential, With Hill Descent Control
#94
Do not order this part for a 2011. As reported on the "other forum" this part has issues on the 2011 with getting 4Lo to work correctly. Instead stick with the 2011 Raptor Part
#95
It looks like I'll be ordering the Raptor AL3Z-7E453-DC part.
#98
The 2011 TCCM is not the way to go. I plan to try the 2011 Raptor TCCM. I left my Raptor switch in so it will be just unplugging the stock TCCM and plugging in the Raptor one - hopefully.
Any 2012 owners out there looking for a spare TCCM? I have one for sale. Only had it in the vehicle for about an hour, LOL :o
#99
#100
#101
E locker fix
***right now i only know the parts for the 2009-2010 f150s so if you have a 2011 do not buy these parts, there are people saying these don't work for 2011***what this does is locks your electronic locking rear differential in 2 wheel high up to 15-20 mph, it also allows you to stay locked in 4 hi & low to unlimited speed.this works great if your in the mud and don't require 4x4 but would like your rear end locked or a fix for your open differential basically like making it like LSD for speeds under 20mph. to acquire this mod you will need part #AL3Z-7E453-DC Motorcraft #TM-233 which is the raptor tccm (transfer case control module) & part #AL3Z-14B166-BA which is the raptor 4x4 control switch located on your dash board, both together should run you about $150 from tascapart.com.. both parts are plug and play with f-150's from 2009 up to 2011 with the electronic locking differential(all fx4's not sure on other trim types). stock 4x4 select switch located on your dash is quite easy to replace with the raptor 4x4 switch.. what i did was stick my fingers in air vent right next to the switch and pull, the silver dash piece will pop up so you can get to the back of the 4x4 switch, unplug the connector in back of switch don't let it fall back into the dash (might be a pain to retrieve).. push the switch towards you from the back side & will pop right out, reverse this process to install raptor switch.. now onto the tccm module. this is a bit of a pain taking it out, took me about 15 minutes to get the module out and about 10 to get the new one in, just in an awkward location.. you will find your tccm module under the passenger kicker panel above your in cabin fuse box, so you kinda have to do this mod with your left hand reaching up into your dash.. there are 2 i think 8mm bolts holding this module to the inside wall of your truck. what i did was loosen the bolt to the left(front of the truck) about half way and completely take out the right bolt (closer to passenger door) slide the tccm out from under the left bolt & drop down so you can see what your doing. next you disconnect the 2 connectors that are on the bottom of your tccm, take raptor tccm plug connectors in corresponding spots & reverse for re-installing the raptor tccm back onto the inside wall of your truck.. now get in your truck start er up & try it out! now that you have the raptor tccm, there is a possible mod you can do to have the raptor off road switch, people are still in the process of working out the kinks with their off road mode but it is out there. i found this mod on another forum & decided to share this with everybody here.. original post on other site start out at page 7 for info and actual installhttp://www.f150forum.com/f38/e-locke...ide-mod-83937/
#102
a bit confusing?
