Sponsored by: DashLynx
H7U vs. H7 - Need HELP
Old 01-17-2011, 03:07 PM
F-amous150's Avatar
What is the difference between a H7 and H7U bulb?? Reason I ask is because I have the halo/projector headlights and took them apart earlier to find a H7U bulb.....I want to put HID's in the low beams but dont know if I need the H7U bulb or an H7 would do...
Old 01-17-2011, 03:33 PM
Raptor05121's Avatar
An additional letter usually indicates the shape of the bulb. Can you post a picture? As long as its a PX26d base, you can order an H7 kit and it should fit.
Old 01-17-2011, 04:06 PM
F-amous150's Avatar
Unfortunately I only have a picture of the BACKSIDE of the bulb and not the front but the front is a fairly small sized bulb.....
Heres the back:
Old 01-17-2011, 04:08 PM
The base looks normal. I wouldn't worry. Just get an H7 HID kit
Old 01-17-2011, 06:49 PM
F-amous150's Avatar
Any idea why there are wires like that.....it looks like its soldered on or something instead of a harness to plug into like my fogs were. I want to do the install myself but when i saw this is kind of confused me.
Old 01-17-2011, 10:31 PM
You'd have to get a better picture for me. But this is what the power harness should look like:
When you get the HID, just plug the two wires into there, then into the ballast and from the ballast into the bulb.
H7 HID bulb seated inside the retention clips
Old 01-26-2011, 10:28 PM
F-amous150's Avatar
Thanks for the info. everything worked out great and got them installed!
Old 01-27-2011, 10:44 AM
Good to hear!
Quick Reply: H7U vs. H7 - Need HELP
