Sponsored by: DashLynx
Torque Specs
Old 02-23-2014, 04:15 PM
glc is offline
Book says 12 ft/lb but I think I'd go a bit more than that.
Old 02-01-2015, 05:04 PM
Forrest_F150's Avatar
Originally Posted by d4studmuf1n
Brake caliper guide pin bolt: 74 nm 55 lb-ft
FYI
55ft lbs on these and I stripped the female threads in both guide pins and necked out both bolts. I wasn't wrenching hard either, it got a little tight, not much at all, then loosened up.
Old 05-08-2019, 02:51 PM
supercrewss's Avatar
Front axle mount torque specs 2010 f150 fx4 5.4L
Hey, I was curious if anyone has the torque specs for the front axle carrier bolts, the ones that mount the front axle to the frame?
Thank you and happy wrenchin!
Old 05-08-2019, 04:57 PM
glc is offline
On what? We can't see your truck through the Internet.
Old 05-13-2019, 02:50 PM
2010 f150 fx4 5.4L 4x4
Old 08-11-2021, 09:14 PM
PopsTruck's Avatar
Post 1999 Ford F150 4.2L project Help Please
Ignore my comments.
Last edited by PopsTruck; 08-12-2021 at 12:10 AM. Reason: Trying to delete this post.
Old 08-11-2021, 09:24 PM
gDMJoe's Avatar
Exclamation
PopsTruck...
*heads-up*...
  • You've posted in the 2009 - 2014 F-150 forum. » 1997 - 2003 F-150
  • The thread is 11-years old.
  • The last, previous post was 2-years ago.
Rather than hijacking the thread would recommend starting your own thread in the above noted forum.
Old 08-12-2021, 12:08 AM
PopsTruck's Avatar
gDMJoe,
Thank you. Felt like I posted in a wrong place.
How can I remove this?
Old 08-12-2021, 10:14 AM
glc is offline
You can't delete posts, I see you edited it, that's the best you can do.
Quick Reply: Torque Specs
