HomeLink Visor in FX4
You can buy the module on ebay for about $20 and add it on. There is a cut-out in the visor already moulded into it. There is enough wire for the vanity lights to run over to the module. You only have to push the wires through the blade connectors on the module to make a connection. When you take the visor off pull the wiring out a bit from the roof and there is a connector in the harness. The visor is two piece (top side and mirror side like a sandwich). It comes apart on the end by prying it at the seam. The fabric is held on by teeth on the inside of the visor where the two pieces meet. I used a stone colored module and it matches my FX4 great. Make sure when you are shopping for a module that you know if you need rolling code or not.
This is the type used in the F150:
This thread may help: http://www.f150forum.com/f38/homelink-48494/
I used this as a guide, it's the same for the F150: http://www.escape-city.com/viewtopic...st=0&sk=t&sd=a
Here are several for $20 to $30: http://shop.ebay.com/i.html?_nkw=hom....c0.m270.l1313
Also you can remove those airbag stickers on the visor by heating them up and slowly pulling them off.
I have a Ingot Silver FX4 with black interior - the visors are actually "Stone". The Homelink module looks tan (advertised as gray on ebay), but matches pretty well.
Ideas for XLT visor without the lighted mirror
I just got a 2011 XLT and I have the visor without the lighted mirror. From where could I get power for the HomeLink module?
The module I added is powered by the mirror vanity light (not switched). The homelink module must have some sort of security feature that shuts it down after a while because I have to start the truck in order for the module to work if my truck has been sitting outside for any period of time. Unless there is a feature that the truck cuts power to those lights so many minutes after shutting the truck off in case they are left on? Either way it's better than leaving a remote in the truck.
