Phaser, Lifter I DONT KNOW,,,HELP!!!!
Old 02-10-2017, 09:17 PM
Roadie's Avatar
Originally Posted by Firewater23
Anyone have the no power going to fuel pump on f150 i have it on my 2000 150 right now i have power to fuses and relaysbut not a drop of power going
To fuelpump???
Inertia switch?
Old 02-10-2017, 11:54 PM
Firewater23's Avatar
Location: soon driving my 66 gmc PD4107 motorhome to WEST VIRGINIA TO STAY IN TILL I FIND A HOME TO BUY
Seems fine not raised up still set Thanx im putting s hot wire switch in so ill have to turn it on every time not sure how its going to work but really need the truck to run so i can ship it has to drive thanx for the information tho
Old 02-11-2017, 12:45 AM
EBC-150's Avatar
Originally Posted by WAFORD
Funny you should mention that EBC, because I just replaced the solenoid and the hub actuators 2 weeks ago.
Yes, but if the check valves are bad, then the IWE's will still try to engage during low engine vac. conditions. Did you try to get the 'ticking' with it in 4WD?
Old 02-11-2017, 12:51 AM
EBC-150's Avatar
To fuelpump???
You're in the wrong section and should start your own thread to get more exposure to your problem. Does that generation have the FPDM? I'd look there if it does...
Old 02-11-2017, 01:08 AM
glc is offline
No FPDM till 2004.
Firewater, please don't hijack threads on unrelated issues. That's what "New Thread" is for. Also please be mindful which forum you are posting in - you have a 2000 but this is the 2004-2008 forum. Thank you.
Old 02-12-2017, 10:18 AM
WAFORD's Avatar
Well I'm not going to try to drive the truck at 50+mph in 4wd EBC. However, after I changed those parts, and got my sciatic back to where I wasn't in pain, I did check to see if the CV shafts were turning while in 2wd. Luckily they weren't. Yes, that job was definitely and literally a pain in the ***/back.
Old 02-12-2017, 10:20 AM
WAFORD's Avatar
Amen glc.
Old 02-12-2017, 12:06 PM
EBC-150's Avatar
Check this thread out: http://www.ford-trucks.com/forums/83...then-some.html
Diagnosing function of the IWE's with it jacked up is not the definitive check to proper 4WD function. I'm still betting on bad check valves in the system. Anyway, I'll drop it at that. Best of luck in your diagnosis man!
Old 02-12-2017, 01:48 PM
glc is offline
We have the same thread right here...........
https://www.f150online.com/forums/ar...then-some.html
