Leveled + body lift = 37s?
Not without some trimming of sheet metal and rubbing. But they could be stuffed in there using a narrow wheel with the perfect back spacing as well as a not too aggressive tire that's no more than 12.50 wide.
The metal on the inner fender behind the tire under that rubber wheel well liner. Especially when going over bumps with the wheel turned any, so any form of flex while off-road will pretty much be gone.
You'll also most likely rub the frame when at full lock.
As far as wheels, something around 8-9" wide. As far as backspacing I can't say an exact number as I don't have any first hand experience with your body style truck but you want whatever tucks in the most while still clearing the control arms and stuff. The further you push the wheel out the worse the rubbing will be.
Also, with 37's don't forget about regearing otherwise you'll be putting a lot of stress on the motor and trans. And 37's in combination with a 3" leveling kit is going to be putting a lot of stress on ball joints and wheel bearings.
I'm not worried about wheel travel as this truck is my wife's mall crawler(was mine until my work bought me a new one). I plan on regearing it this winter. I don't mind trimming the fenders some if need be. Is there any fender flares that I could use to help cover up the cuts? Or would they just make it worse?
However, I know that's not what your asking, now back to your questions. Just offering advice.
Most 2004/2006s had an exposed IWE solenoid and 2007/2008s had an updated boxed in style one. The reason being water from the wiper cowl could get into the IWE and water could get into the breather line for the IWEs slowly causing them to become inoperable. Not a bad repair, just an inconvenient repair. If you have an exposed original IWE solenoid I would certainly replace it asap with the updated design.
