2006 f150....
2006 f150....
Bad phaser and tensioner on passenger side. Slight wear marks on timid g cover.
Cam phaser bolts cracked lose and do not have spring compression valve tool.
Looking to release cam caps instead of using tool.
Do I release cam caps at 12 o clock or 6 o'clock.
What about reinstall?
This place has the tool here:
http://www.shopfreedomracing.com/Val...9-303-1039.htm
Summit racing has it here, which is local:
http://www.summitracing.com/parts/otc-6684
Are there any places Akron/Canton that you can rent the tool?
I believe unlocking the cam caps would be easier than spending $150-170 on a tool.
