P0446 Error
Old 07-30-2015, 06:32 PM
Brobones's Avatar
P0446 Error
P0446 Evaporative Emmission Control System Vent Control Circuit
I dropped the spare tire removed the canister and tested the Vent solenoid.
I used 12 volts and tested the solenoid it functioned fine. I then turned the key on to the run position and tested the incoming voltage it measure just over 5 volts.
I was going to bolt the canister back up but I wanted to see if I could feel and or hear the solenoid activate when the key was in the run position.
I had my wife turn the truck on to the run position and nothing the solenoid never got activated. I then tested the the connection and no voltage.
I peeled back about a yard of the wire but never found any break or bend. I tested the wiring about 2' feet back from the connection and still no voltage.
I do not have a wiring diagram for the truck, I can not find any fuse that would be associated with the EVAP system.
Any info would be appreciated.
2008 Lariat 5.4
Bro
Old 07-31-2015, 11:52 AM
Brobones's Avatar
Over 150 views and nothing... there has to be someone else that had this type of trouble...
Old 03-23-2016, 09:20 PM
sheanes's Avatar
Check the wiring all the way back had mine on 2004 broken in harness. Gave a good pull on it and it broke in half. Wire corroded.
Quick Reply: P0446 Error
