Lariat to FX4 Speedometer cluster Swap
As the title says curious if i can swap the Cluster in my 04 Lariat to a FX4 without going to the dealer and have everything working. i tried searching but i couldn't find anything concrete on this.
My speedometer right now shows me running 120 MPH all the time.
FX4 dash, but manual AC:
Lariat (see info center buttons by ignition?):
So, you can indeed swap an FX4 cluster in, but be sure it came from a truck with EATC like a lariat would have or it gets tricky.
So, time to do some reading.
FYI:
Back in June I swapped my '04 xlt to a 05 FX4 cluster from a truck WITH COLUMN shift. You have to keep like shifting together. I looked for the PDNR12 in the pictures when I bought mine. Everything works. Just need to have my mileage reprogrammed which I will be doing soon through a reputable company.
I replaced my Lariat cluster with one from an FX4 with manual air. I went to the local Ford dealer and they reprogrammed the cluster. Of course they couldn’t change the mileage and my information buttons no longer work, but I was just glad that they fixed the A/C situation. Everything else is good now.
