2008 fordf150 stalling issues
Stacey, welcome to the forum! I've moved your thread into the 2004-2008 model year section. You should get better responses here than in the section set up for suggestions to improve the forum itself.
How many miles are on the plugs? You say you "changed" the throttle body - do you mean you cleaned the MAF environment and the sensor? The sensor itself is very easily damaged, is it possible this might have happened?
- Jack
- Jack
Whoever told you to change the throttle body led you very astray. Maybe cleaning it might have fixed it, but at least you know it wasn't the throttle body.
At 71k, it's about time for a plug change. I'd clean (NOT replace) the MAF sensor. If the new throttle body didn't come with a TPS, your original one may be bad.
