'05 5.4 thinking of new engine
My '05 XLT just ticked over the 200K mark on a trip up to Seattle and back. I added 3 qts of oil to get it up to proper level after the trip. It also has the morning starting 'chirp', which appears to be a lifter problem.
I just put in a new tranny and the truck is mint so thinking of a new engine. My guess is the new eco boost engine won't match my new tranny (?) so what are my best options? If there was a diesel option I'd be all over it as I was hoping the new 2015 body was going to come with a diesel.
-Chris
-Chris
I hate it for Ya! I was where you are last year. I had the roller bearing on a follower/roller rocker fail so the cam ground it up and sent the powdered metal throughout the engine.
Like yours, my truck is nice so I replaced the motor. I looked at other options but I decided to just stick with the 5.4 and find another.
I got a nice low mile 5.4 for a little over $2400. After install I was in it for a about 5K.
Good Luck
Good Luck
From an economic standpoint, I would say replacing the 5.4 is the only way to go. Also, with over 200k on the truck, I'd have to think REALLY hard about whether I wanted to dump that kind of money into the vehicle. It may be mint, but all of the underpinnings and related mechanicals are getting toward the end of their service life at this point.
If I do the engine I'd probably go with a new exhaust and other potential worn areas like wheel bearings etc.
I figure that doing this will be cheaper in the short term (another 100K) as I really would like to see if they come out with a 150 diesel or I move up to a 250.
Any tips on where to find a great low mileage 5.4? Call the yards?
Thx,
Chris
I googled used 5.4L 3 valve engine's, and sent out a few inquiries. I ended up buying it from a yard in Florida and they shipped it to me. They "claimed" it had 36K miles on it but who really knows. It came out of an '06. I took a chance and it does run and sound great.
I paid $2400 for the used engine shipped. I had a trusted friend at a local shop install it which was around $2200 and included new plugs, oil change, and all fluids. I also bought a new throttle body. I had new catts installed because the poorly running old engine killed my catts.
I looked at reman engines and they range from $3-4000 plus install ($2200). I got a quote from my local Ford dealer for $5K for a Ford replacement engine plus install($2200).
After it as all said and done I have a little over $5200 in it. I have no truck payments so it as well worth it I guess. I plan to drive it for a few years more years now. LOL
How does this look? http://www.advancedenginex.com/2004-...-block-engine/
Price looks good and would give me room to add other new parts. My cousin's shop can install for around $1500 so seems like a good option?
I'd like the end result to be better than before so imagine I would have to also replace coil packs and do a total clean to the throttle body.
The truck has done some serious towing and has been great so why not have it around for a few more years?
-Chris
Wouldn't buying and installing a new reman engine with warranty be better?
-Chris
-Chris
I can't argue with that... they are ****'s but there is some wiggle room. I haven't read smog laws in a LONG time but the last I read, you must use an engine that was available in that body/model OR you must use the full emissions from the donor car. A lot of guys bought 4 cylinder mustangs and converted them to 5.0 or even go 351/5.8 in Cali, smog shops did not care, so long as your 302/351 had ALL the smog BS they were expecting to see. I seem to recall the 351 being an option because of some limited edition race mustang offered in 93 with a 351 from the factory, but don't quote me on that. Now for the crazy, there were guys putting chevy 350's in their mustangs in the 80s and so long as you use the full donor car's emissions setup they were ok. Of course I think they ended up at a smog referee EVERY 2 years for smog because none of the mom and pop smog shops would touch it with a 10 foot pole. I'm not sure how this would work with a diesel since there's no emissions.
