Can someone with a stock height 2wd take a measurement for me?
On the front, from the center of your center cap to the lip of the wheel well arch? I never mesured before adding taller shocks and would like to know how much I gained since I'm going to change something. Thanks for your time if you can!
A v6 2wd reg can would be best, but any 2wd will give me an idea. Thanks again.
You'll probably be right under 22" with the quick lifts. I wonder, if I removed my 4x4 coilovers and went to quick lifts, if that would drop be down an inch? Maybe the Rancho guy will see this post.
Here are the measurements on the RS999909 QLL 2WD
Comp 16.75
Ext 21.75
Travel 5.063
Comp 16.75
Ext 21.75
Travel 5.063
Thanks so much for doing that for me! My truck is at exactly 23" from the center of the wheel cap to the wheel arch lip. I definitely want to come down an inch!
This may or may not help. I have an Autospring 1.5" level in the front and mine measures exactly 23" center to fender. I had taken measurements prior to install a few years ago but cannot find them. I think I got close to 1 3/4" lift. My truck also has 265/70/17 tires.
Also, if you're at 23" like I am, that must mean our lighter 2wd v6 trucks sit higher than a 5.4 2wd screw, as kevinpmac said his is at 19.75" and that must also mean your truck was around 21.25" prior to your 1.5" spacer. pretty big difference.
Id like to be at exactly 22 - 22.25" up front. That would be the ideal stance and also idea as far as UCA angles. Mine don't rub or anything and I've had this set up for probably 30k miles, but they still look a little severe.
Thanks for everyone's time.
I spent the day installing upper control arms, lower ball joints, stabilizer bar kit, Rancho QuickLIFT fronts and 9000's on the rear. I am really liking the level look!
My front measurement went from 19.75" (per above post) to now 22.75" when measured at same level location. My front springs must have been tired after 106k.
My front measurement went from 29.75" (per above post) to now 32.75" when measured at same level location. My front springs must have been tired after 106k.
