18x10 +10 33x12.5x18?
18x10 +10 35x12.5x18?
Would this work on a stock height 04 lariat 4WD? If not would a 2.5" level kit make it work?
They have 325/65/18 on them right now but I am not trying to make my truck look like a monster truck. I am trying to get a better stance without jacking the truck up super high.
TIA
TIA
Assuming you haven't bought them and are interested, yes this is close to a 35". I would suggest no. At least a 2.5" level to clear it. At the same time the wheel specs might be ok since the offset isn't negative.
If it is local to you I would ask to test fit one if the seller would kindly allow you to. But, a 325 is a big tire. I would suggest stick to a 305 tops.
My first post was a typo as they are 35 MTZ's which are huge and they come out to 35 x 13.5". I tried to test fit them but couldn't jack the truck high enough to get them on! I ordered a 2.5" level kit but not even sure they will work with that.
I can size down to 33's if need be, probably a 305/65/18.
Any ideas?
Any ideas?
Yea those won't come close to fitting without at least a 2.5" level kit and after that they may not fit. Aggressive tread + wide rims with that much backspace are going to cause problems with rubbing your control arms and possibly the outside of the fender. I'm not even sure a 6 inch lift would not rub a little.
