Tire Time
Tire Time
Alright, first things first, I apologize for being "that guy" but I've looked for a long time and can't find what I need to spend $1100 over the interwebs. I have a 2005 FX4 (stock 18s) with bilstein 5100s that I thought were supposed to level the truck but seem to be a bit shy (wondering if they're just set wrong and it should sit Level at its highest setting?). I'm looking at a 33.4" tire or a 34.25" (cooper st maxx). With the bilstein adjustable can I fit the 34.25" without an issue? I've had 305/65 on here with an AS level but I'm concerned about the bigger size with just the adjustable shocks.
Those Bilsteins are adjustable. What are the full dimensions of those Coopers? You shouldn't have a problem fitting them from a height standpoint, but if they're 305s or wider, you may rub the frame and/or UCAs.
Also, don't know what state you're in, but Discount Tire should be able to get you the best price on those Coopers, let you test fit one to see how it fits (but obviously you'll "own" the tire after this), and not be a sketchy online site with no returns.
What size was that AS?
If it's the same size, the tire brand doesn't matter. Nittos run larger than Coopers (I have Trail Grapplers and my 35s are bigger than Cooper 35s, both on F150s with 20" wheels), so if that size Nitto fits, Coopers definitely will.
I want to say it was only a 1.5" that I ran 315/65 BFGs on. The Trails are definitely taller but not wider according to manufacturer stats, wider is what worries me for the control arms. Is it worth it to pay $25 more per tire to change and go with the Nittos instead, knowing they're verified to fit already?
Mmm . . . you've gotta make that call. Trail Grapplers are usually taller and wider than other tires of the same size, but I saw you list the specs for the Coops in the other thread. I paid $400 extra for Trail Grapplers than STT's because I know they last for a very long time, so maybe it's worth it for fitment and tire life. But, every lifted truck (mostly diesels) owned by Discount Tire employees in my area all have Cooper STTs, for whatever that's worth. Knowing what I know now, I very easily could've gotten the Coopers. I don't think you can make a mistake with either, and the specs are so close.
